Sponsored by: Real Truck
Vibration
Old May 23, 2014 | 08:53 PM
xd2200's Avatar
xd2200
Vibration
Hello - I have a 2002 SD 4WD auto trans extended cab/short bed (92K miles). Run 55psi front and 70 psi rear per door placard. Recently started getting a vibration when cruising at 45MPH and to a lesser extent at 55MPH. I was due for new tires so I got Hercules which where balanced and also had the alignment checked (no problems.) Vibration has subsided greatly but still does it at 45MPH. A little faster or slower and it goes away. I checked the u-joints on the (one-piece) driveshaft and they seem tight. I do not feel any vibration in the steering wheel but really cannot tell if it is coming from the front or the rear. Any thoughts on possible gremlin would be appreciated
Old May 24, 2014 | 08:34 AM
72f250CS's Avatar
72f250CS
Im assuming you feel it in the seat? If so, its often towards the rear, feel it in the steering wheel its often towards the front. I have a vibration in the seat at 55-60, u-joints good, tires good. Im looking toward shocks(107k miles) on them, and servicing the rear end. Couple ideas for ya... Jay
Old May 24, 2014 | 09:24 AM
kengarchow's Avatar
kengarchow
in my 99 i had a similar vibration
ended up pulling the rear driveline and driving it in 4wd, vibration gone
had shaft rebalanced, been smooth ever since
Old May 24, 2014 | 10:30 PM
99f350sd's Avatar
99f350sd
Pull the rear drive shaft and check ujoints for smooth operation by hand..Thats the only way.
Dave042
2009 - 2014 F150
38
Jun 25, 2024 10:35 AM
andres0517
Apr 20, 2020 11:39 AM
blackbeautyf250
Apr 4, 2013 05:22 PM
dines78
Dec 10, 2012 07:35 AM
