Front leaf spring question...
Old Oct 22, 2008 | 08:32 PM
ExcursionSVOand5.0's Avatar
ExcursionSVOand5.0
Took a look at mine the other day and I think the front leaf springs on my 02 might be de-arching. Could someone take a measurement right where top of the leaf spring is over the axle to the frame? My rubber bumpers are completely missing as well.
Thanks
Rob
Old Oct 25, 2008 | 05:22 PM
ExcursionSVOand5.0
Can anyone measure theirs for me? I'll send the ruler..lol
Old Oct 25, 2008 | 06:12 PM
cbradford's Avatar
cbradford
5.5" this is taken just in front of U bolt/shock bracket top of leaf spring to botton of frame, hope this helps you.
Old Oct 25, 2008 | 07:56 PM
xr7390GT's Avatar
xr7390GT
Best fix is U or V code springs from Superduty, and buy new bump stops. Excursion stock springs are no good.
Old Oct 25, 2008 | 10:37 PM
1's Avatar
Measure from the center of the 4X4 hub to the bottom of the fender lip, that way you dont have to go crawling under your car.
Gonna go see if I can find a tape masure real quick.
EDIT: 23 and a touch under a 1/4" from the center of the 4X4 hub to the bottom edge of the fender for my 03 limited. I think I got the new suspension as I was a very latye 03 build and I have the rear swaybar. Not sure if the updated suspension changed ride height at all.
Old Oct 25, 2008 | 11:17 PM
ExcursionSVOand5.0
Gotta measure it in the morn...thanks guys.
Are your's de-arched as well or is it just because mine is old?
Old Oct 26, 2008 | 05:04 AM
1's Avatar
I think mine are still fine? I have some clearance between the bump stops and the axle, not sure how much. I'll check that tomm after my driveways dry. I was washing another car all day in preparation for winter storage so I didnt wanna lay under my truck on a wet driveway tonight lol.
Old Oct 26, 2008 | 05:17 AM
cbradford's Avatar
cbradford
I did not lay under to take measurement went over tire, there is enough clearance to lay my chest on front tire and measure and I'm not a small guy.
kioolt
Oct 25, 2013 05:12 PM
shawn11762010
May 13, 2011 08:07 PM
Csticks
Feb 23, 2011 03:22 PM
79f100six
Offroad & 4x4
Feb 14, 2008 01:01 PM
my64ford
Jan 29, 2003 09:49 PM
