Gear ratio
Old 10-22-2008, 06:32 PM
tunaluvr's Avatar
tunaluvr
tunaluvr is offline
Gear ratio
How do I find out what type of gear ratio a truck has. I tried to put in the VIN # but it doesnt' give me the gear ratio. Its a 96 F150 XL 4X4 with a 5.8L motor. Extra cab, short bed. Anyone know if what it comes standard with?
Old 10-22-2008, 08:15 PM
Conanski's Avatar
Conanski
Conanski is online now
There is no standard, look at the axle code on the door jamb sticker.
Old 10-22-2008, 08:24 PM
94MustangGT's Avatar
94MustangGT
94MustangGT is offline
^ +1
You could also look at the axle tag ( held in place by a bolt on the cover )
Ex. 3L55 = 3.55's with a T-Lok and 3 55 = 3.55's with an open diff.
Old 10-22-2008, 08:41 PM
Dustin1690's Avatar
Dustin1690
Dustin1690 is offline
Look at the axle code then go under articles and specs vin decoder then to gear ratio decoder but I can tell you now 19 is 3.55 non limited slip H9 is 3.55 limited slip
Old 10-23-2008, 01:06 AM
injville's Avatar
injville
injville is offline
If you have the owners manual, it will tell you what the letter in the door jam stands for.
Old 10-23-2008, 02:39 AM
tunaluvr's Avatar
tunaluvr
tunaluvr is offline
Thanks for all the information. I'm looking to buy a used one so wanted to know some information. Anyone unhappy with this truck and motor. I currently have a 97 F250 HD with the 460 motor and I'm very disappointed with that motor. No yank for that size. Looking to sell my F250 and buy the F150 instead. Any mod's to really get the yank on the 351 motor?
Old 10-23-2008, 03:00 AM
Creel's Avatar
Creel
Creel is offline
If you're disappointed with a 460, you're going to be even more disappointed with the 351. Find out what your 460's rear end ratio is, a better one may make a huge difference.
Old 10-23-2008, 11:12 AM
94MustangGT
The truck in my sig feels strong, and I a daily drive a geared 5.0 Mustang. The only thing thats not factory stock on the truck are the Warn manual hubs and 31" tires. Of course I usually ease around in it most of the time(it has nice low end torque,) but will move out if the need arises. The intake and exhaust are pretty restricitve, so you should focus on those if you are looking for more HP at the top of the tach. Keeping it maintained also plays a big part, cap & rotor, plugs & wires, air & fuel filters, etc.
Old 10-23-2008, 04:48 PM
tunaluvr's Avatar
tunaluvr
tunaluvr is offline
Thanks for the information. Any other mods for the truck to boost up HP besides intake and exhaust? Something not to hard or really expensive.
Looking foward to this truck. I love the look of the older ford trucks.
Old 10-23-2008, 04:52 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,661 Likes on 1,355 Posts
Hawaii? Better check those smog laws etc. You can't be worse than CA, but you could be the same, in which case you're hop up parts have to be approved.
Old 10-24-2008, 12:08 AM
94MustangGT
If it were my truck, I would put a new Motorcraft cap and rotor on it along with Motorcraft spark plugs. Also put on a set of Ford Racing 9MM plug wires. Change the air and fuel filters, then see what you think. Also make sure the oil/tranny fluid/T-case fluid/ and both axle fluid are clean. Use synthetic if you have the money. I would be leary of putting synthetic in an older motor and tranny though... There a nice "Hi-Po" tune up. You could also advance the timing if you want to run higher octane gas.
If you feel like spending more $$$, put a nice free flowing muffler on it. A CAI should work well, but I wont put one on mine because I go off-road.
After that, emission legal parts can be expensive for miminmal gains. Throttle bodies, high flow cats, short tube headers, etc.
You could get a programer for a '96, but I dont have any experience with those.
darren_palms
12-16-2013 01:19 PM
lonewolf777
1983 - 2012 Ranger & B-Series
01-28-2011 09:11 PM
91dirtydiesel
12-19-2008 01:39 AM
dieseldoc
11-22-2006 08:36 AM
gsx
04-07-2002 11:50 AM
Quick Reply: Gear ratio
