Aerostar Ford Aerostar
dumb question
Old Oct 22, 2008 | 05:48 PM
z1121jack's Avatar
z1121jack
dumb question
I recently purchased a used 97 aerostar and was trying to change the oil today. I found the oil filter, OK. But. can not find the drain plug.
there is a square (about 1/2") on the driver's side rear of engine but it is really tight.
Thought I would try to get some Advice before proceeding. It is a 4.0 engine. Someone please help me identify the oil drain
Old Oct 22, 2008 | 06:43 PM
xlt4wd90's Avatar
xlt4wd90
The drain plug should be just above one of the cross members near the rear of the cast aluminum oil pan. It is like a bolt with a 1/2" or maybe 13 mm head. One you remove it, the oil will conveniently drip onto the Y-pipe, so the next time you run the engine, it will smoke for a while.
Old Oct 22, 2008 | 06:46 PM
99f350sd's Avatar
99f350sd
Yea its easy to get to on the pass side behind the front wheel....
Old Oct 22, 2008 | 07:56 PM
copper_90680's Avatar
copper_90680
The drain plug on the 4.0L is not on the rear and on the side of the oil pan as in most cars. It is right on the bottom face, so you have to look straight up at the oil pan to see it.
Welcome to the club
Old Oct 22, 2008 | 08:25 PM
z1121jack's Avatar
z1121jack
what does it look like? size? I only saw a small square plug about /2". See nothing that could be oil drain near center of oil pan
Old Oct 22, 2008 | 08:53 PM
94MustangGT's Avatar
94MustangGT
^ I guess previous owners could have replaced drain plugs, but my parent's '95 4.0 needs a 5/8" socket. The oil pan is metal with a network lines/ridges cast into in, and the oil drain plug should be the only drain plug in that area ( or anywhere really.)
Old Oct 22, 2008 | 09:50 PM
96_4wdr's Avatar
96_4wdr
AutoZone.com | Vehicle Selection - Year
Old Oct 23, 2008 | 05:36 AM
z1121jack's Avatar
z1121jack
thaks for the drawing
Old Oct 23, 2008 | 05:47 AM
96_4wdr's Avatar
96_4wdr
no question is dumb z1121jack
glad ur caring on the great Aero owner tradition of DIYer.
my Dodge/Cummins dealer wants $200 to change the oil in my new tow machine.
i'll keep the money for myself and do it this weekend.
can't say i love working under the hood of the Aero, but the old girl is so dependable and simple, even i can understand how she works.
sure wish Ford would wise up and start building owner friendly cars again instead of this junke they can't sell, loaded with every gadget and no work miracle
maybe we'll have to wait for the Chinese to fill the US auto industry needs
Old Oct 23, 2008 | 01:40 PM
Pablo-UA's Avatar
Pablo-UA
i have 16mm plug head....
Old Oct 23, 2008 | 03:28 PM
copper_90680
Jack,
Can you snap a picture and post it here? We can tell better if we actually see the plug you mentioned.
Old Oct 23, 2008 | 11:52 PM
marty600's Avatar
marty600
China???
No, even the valve stems are junk..but of course, their sales march onward,
so thay get the cash needed to upgrade their processes...
I still think US autos/trucks are light years ahead of the imports when it comes time to do some maintenance/repair, I have owned 4 japanese rides,
and was glad to get rid of each one..conversely, all my US machines were treasured to the end, and that has always been over 100k on the odometer.
I am patiently waiting for the fiesta, my first new car in years!
If they offer a diesel, i will waiting at the door, but that prob. will not happen, due to the EPA. But the cummins engine is the best, no prechamber so it sounds fantastic. They should make a 1.5l and sell to the big 3. Second place goes to the germans. In close 3rd is international (powerstroke)
And then we have duramax, GM sourced by ISUZU. They don't sell diesels in thier own country, the prime minister does not like the smell, so he told them not to produce anything for local consumption. Send it to the US, they will buy anything (and that brings us back to the china issue!)
I will pay more to support my nieghbors' jobs, and thus my own...
Old Oct 24, 2008 | 10:40 AM
aerocolorado's Avatar
aerocolorado
Its quite possible a previous owner/lube shop stripped out the original plug and substituted an old fashioned, square headed plumbing plug instead. If so, those plugs have a tapering thread and they will necessarily be very tight in order to seal effectively. I hope not, as the soft aluminum pan will not hold up to repeated use of this type plug. A picture would help.
Old Oct 24, 2008 | 02:29 PM
96_4wdr's Avatar
96_4wdr
lots of newer rigs out there dribbling oil from their aluminum pans due to cross threading and over tightening of drain plugs.
expensive repair job requiring oil pan pull to repair properly without metal cuttings inside.
when you hear an air impact wrench in the oil pit at Quickies, you know it's time to leave the line pronto. got the kid down in the hole on the quota system
main reason i quite going to Quickie Rip Off and Oil Drip Henry's
Old Oct 25, 2008 | 03:20 AM
xlt4wd90's Avatar
xlt4wd90
The drain plug on my oil pan had an O-ring that did a pretty good job of sealing it. So it was only necessary to tighten it just enough to prevent the bolt from loosening by itself.
Of course, the oil pan was leaking from at least 3 other places, so sometimes it was hard to tell whether the plug itself was leaking or not.
johnsonjf
Mar 15, 2017 12:55 PM
davidrozeboom1
Aug 17, 2016 10:16 AM
flowney
Jun 7, 2016 11:50 AM
datchew
Sep 16, 2015 05:09 PM
fdude64
Jun 23, 2015 08:35 PM
