Draining FE Engine Oil --- NEATLY
Old Jun 4, 2016 | 06:12 PM
flowney's Avatar
flowney
So has anyone come up with a tidy way to drain the oil in an FE equipped truck? By tidy I mean that the oil goes from the engine directly into a drain pan without first traversing the engine crossmember and steering linkage.
I once tried carving up a quart sized plastic oil container which seemed to work initially but quickly got out of control.
Old Jun 4, 2016 | 06:36 PM
HIO Silver's Avatar
HIO Silver
Using cardboard, I fold a trough to convey the oil into the drain pan. Works for me.
...An alternative is to install a Fumoto valve and the optional drain hose.
http://www.fumotousa.com/results.php...=F-100+6.4L+V8
Old Jun 4, 2016 | 06:39 PM
PA74F250's Avatar
PA74F250
That's a 2wd thing and your right it's messy. My father inlaws 65 F100 is basically the same and we too tried making things but it's still a mess. Some sort of hose and valve setup would be slick.
Old Jun 4, 2016 | 07:58 PM
Steven@nd's Avatar
Steven@nd
I just live with the mess... a friend of mine had these for draining:
Form-A-Funnel® Flexible Draining Tool - 6.5" x 14.5" https://www.amazon.com/dp/B003V9JWHO..._qK3uxb6X9NX7K
Or you can get a Fumoto drain valve with the hose nipple on it.
Old Jun 4, 2016 | 09:30 PM
co425's Avatar
co425
I used to use heavy duty aluminum foil molded to fit around the pan. That is when I had a 2wd camper special.
Old Jun 5, 2016 | 10:24 AM
mountain dewd's Avatar
mountain dewd
All you need is a 4wd truck!
Old Jun 5, 2016 | 05:40 PM
GM4WALLS's Avatar
GM4WALLS
Just cut the crossmember out of the way. Clean oil changes and $.65 in scrap metal!
Old Jun 5, 2016 | 06:27 PM
flowney's Avatar
flowney
Now we're getting into CrownVic IFS territory.
In addition to the Fumoto valve solution, there are a number of others aimed at turbo owners. Apparently, changing oil in a turbo vehicle is an even greater challenge that what we face. For example, see: this,
Old Jun 6, 2016 | 11:53 AM
sluijs01's Avatar
sluijs01
I always did a combination of what HIO Silver & co425 on my motorcycle because the headers passed directly under the oil filter, which guaranteed some nice smoke if you didn't do it. Bent a piece of cardboard and covered it in foil. Haven't done it with a truck yet since it's easy enough to wipe off, but still a good idea.
Old Jun 6, 2016 | 12:06 PM
SlikWillie's Avatar
SlikWillie
What are you talking about? That's rust prevention! Just roll with it.
Old Jun 7, 2016 | 07:13 AM
flowney's Avatar
flowney
Here is a nice animation showing how the Femco system works.
Here are three models that should work on engines using a 1/2-20 plug:
The 90º drain and hose looked to me like it would work better than the straight one.
Old Jun 7, 2016 | 11:50 AM
mountain dewd
Guys, there is an easier way, just remove the engine entirely every time you change the oil.
Flyct
May 26, 2017 02:11 PM
montauk1
6.7L Power Stroke Diesel
Jul 29, 2016 12:48 PM
superduty4x4
21
Jul 31, 2008 12:38 PM
PW01
Oil & Lubrication
Jan 12, 2006 11:19 AM
PW01
1983 - 2012 Ranger & B-Series
Jan 5, 2006 08:36 PM
