Need some guidance
Old Mar 15, 2017 | 12:19 PM
johnsonjf's Avatar
johnsonjf
Need some guidance
Good Morning,
I am trying to finish up an oil cooler upgrade and I am having a problem with the turbo drain tube. I have already replaced the o-rings once and it leaked oil all over the top of the engine when I cranked it. I am not sure if I installed it correctly, maybe someone here can let me know.
Below are pics of the oil drain tube installed, is the positioning correct or do the tabs of the drain tube need to be snapped to the tabs on the turbo pedestal?
Thank you,
Jeff
Old Mar 15, 2017 | 12:55 PM
WatsonR's Avatar
WatsonR
It's right. Just lube the orings or use some assemble lube and drop the turbo straight down on it..
Rod Jr.
Jan 20, 2019 09:58 AM
amill
Nov 7, 2012 04:54 AM
Elvis40
Mar 7, 2011 09:18 AM
SHAWN056.0
Apr 17, 2010 08:58 AM
jlo84truck
Mar 6, 2010 10:42 PM
