Yeah I just rechecked an if you already have cab lights we cant install the LED's. We can get the diferent color covers, clear or smoke. Anyway yours looks great cant wait to see better pics. Atleast something good came off of the Dodge assembly line.
Sarge
The reason that you can't install the Recon LED cablights if you have the factory cablights is because the factory ones have screws that go through the roof from the inside of the cab so the holes are larger than what the Recon ones use.
You can replace your stock bulbs with the same type of LED's that the Recons use and they will look better because they have the LEDs shining each direction. The Recon LEDs only shine forward.
