Hey guys, going to be helping my buddy install cab lights on his 08 Sunday and was just wondering if anything changed drastically from the 07 and down trucks?
Took us 4 hrs because we made sure the holes were right many times. Started sweating when the drill came out!
The 08 i did was pretty much the same as the one in the writeup. The difference is that the wiring harness from Ford that you bought goes on the driver's side while they stated that you replace a harness on the passenger side. The harness plugged into a terminal behind the parking brake. Pretty easy install.
Parts from Ford to do everything yourself will include:
Wiring harness
5 lights
10 nuts (each nut had a washer attached to them)
