removal-fill plug for transmission
Im having trouble getting the fill plug out of the side of my 5 speed manual tranny. I looks like it has some kind of a slot in the middle of it but I can't get it to turn. Am i not holding my mouth right or what? I can't figure out what i need to do to turn this thing. I don't want to pull the shifter so any help would be greatly appriciated. Thanks for your help
It's really a six speed. Does the granny gear not count for some reason? It's another gear. Maybe overdrive shouldn't count, either. Maybe they should call it a direct drive one speed, with granny low, two underdrives (first and second) and an overdrive.
The fill plug is a square head. I forget if it is a 3/8" or 1/2".
Of course if I had my preferences, this would have been an 8 speed. I would add one more gear between the 2-3 (what you would call 3-4) ratio, and tighten up the 4-5 (5-6) ratio, plus add another gear on top, but for some reason no one asked me when they designed these trannys.
05victorylly
03-21-2012 04:33 AM
lemonshindig
03-29-2010 10:59 PM
Quick444
10-04-2009 08:40 PM
Wolfman2405
08-18-2003 08:50 PM
BroncoScott
1978 - 1996 Big Bronco
16
01-02-2003 04:52 PM
