Do-it-yourself Tire Rotation
Old Oct 26, 2008 | 10:29 AM
  #31
1saxman's Avatar
1saxman
The original poster's idea of putting the spare into rotation is correct. It's lot more work, but you may as well use that beautiful new tire hanging back there. You also only have to jack up one corner at a time. Of course, those wise guys with 'rims' and different tires won't be able to do that, and may not be able to use the spare at all if they significantly changed the tire diameter.
Old Oct 26, 2008 | 11:15 AM
  #32
MisterCMK's Avatar
MisterCMK
Not to mention the spares are usually steel wheels.
Old Oct 26, 2008 | 01:22 PM
  #33
Davko's Avatar
Davko
Originally Posted by Big-Red-Lariat
ok, so is it cool to jack up the pumpkin or will it bust like after halloween?
How about 2 jack stands holding up the front wheels, and then jack up the back in the centre of the trailer hitch area?
Any thoughts on this idea? I rotated mine yesterday and used the spare. Just had to change 5 times to get it back under the truck. I'm just really curious how it could be done with all 4 wheels off the ground at once.
Incidently, torqued at 150 ft lbs.
Old Oct 26, 2008 | 03:38 PM
  #34
Big-Red-Lariat's Avatar
Big-Red-Lariat
is 150 ft-lbs the proper torque for 20" aluminum rims?
Old Oct 26, 2008 | 05:20 PM
  #35
Davko's Avatar
Davko
I got the torque figure from my manual.
Old Oct 26, 2008 | 10:11 PM
  #36
SteveVFX4's Avatar
SteveVFX4
Originally Posted by MisterCMK
If you have directional tires you cannot rotate them any other way than from the front to back keeping them on the same side.
Yes I know that and if you opened the link I posted it talks about rotating directional tires too. But since no F-150 comes standard with directional tires, I didn't mention it my post.
Bugzilla46310
All Things Towing
20
Sep 15, 2018 12:56 PM
HRTKD
All Things Towing
Apr 13, 2017 10:14 AM
Rob89
Nov 9, 2016 03:23 PM
Torky2
Escape & Escape Hybrid
Mar 31, 2011 09:17 AM
ssharber
Sep 19, 2009 09:30 PM
