Sponsored by: Real Truck
Tire Rotation
Old Nov 8, 2016 | 01:31 PM
Rob89's Avatar
Rob89
Tire Rotation
Hey guys...I'm going to be rotating my tires in the next few weeks and I'm sorry but where the manual wants me to jack the front of the truck up scares me. the manual wants me to jack it from the front of the control arms...that scares me...however...there is not enough room between the front differential and the driver side wheel for a jack and a jack stand. there is plenty of room on the passenger side to jack from the axle but the driver side has me confused.
do you all jack from the front of the control arms?
Old Nov 9, 2016 | 07:13 AM
sxrfun's Avatar
sxrfun
Why does jacking from the front of the control arms scare you? The control arms are attached to a bracket that's welded to the front axle....Very sturdy place to do it.
What I do is jack up drivers side from the bottom of the front differential....then place jack stand under axle between drivers wheel and differential...lower on to jack stand......place jack under passenger side front control arm.....jack up that side....place jack stand under front axle inboard of where jack is.
Old Nov 9, 2016 | 07:30 AM
Tom's Avatar
Tom
Why wouldn't you want to jack from the control arm? They're big and beefy, you're not gonna hurt them. You'll find flat spots towards the rear that are intended for this purpose.
Old Nov 9, 2016 | 07:41 AM
don123's Avatar
don123
I jack mine from the differentials and put jack stands under the axles as close to the wheels as possible. Never had an issue.
Old Nov 9, 2016 | 10:01 AM
JeepPuller's Avatar
JeepPuller
I just rotated my tires and jacked from the control arm without issue. Be safe.
Old Nov 9, 2016 | 02:27 PM
Rob89's Avatar
Rob89
Thanks for the replies. I'll jack from the control arms.
Old Nov 9, 2016 | 03:23 PM
ReadyToMount's Avatar
ReadyToMount
Former Vendor
I typically use jack stands on the front to hold the axle and vehicle level. Then lift the rear by the hogs head. Then I can do the rotation pretty quick without too much jacking.
Cool Ron
Sep 28, 2017 06:25 PM
speakerfritz
Apr 27, 2015 11:29 PM
Big-Red-Lariat
2004 - 2008 F150
35
Oct 26, 2008 10:11 PM
mrc59
Jun 12, 2004 06:05 AM
Jupiter Coyote
1997 - 2003 F150
Apr 20, 2004 01:54 PM
