how to remove emblems
Old Oct 20, 2008 | 01:56 PM
F.ROCK's Avatar
F.ROCK
my f1 has the custom cab logos on the door. i need to safely remove them to be re used. any tips? they seem to be pressed in w/out clips but i didnt look real closely. thanks!
Old Oct 20, 2008 | 03:34 PM
Julies Cool F1's Avatar
Julies Cool F1
Hi Rock,
The 48-52 F1s did not come with Custom Cab Logo's originally. The fancy schmancy version of the Bonus Builts was the "Five Star Deluxe Cab" model. So, someone has added those to your truck. Chances are they are glued on, or held in place by "push nuts" inside the door. The push nuts will be fairly small and flat against the inside sheet metal.
Chances are if there are no clips or push nuts (which will be fairly small and close to the sheet metal) they are glued on. If that is the case you are just going to have to gently pry them off.
OBTW if you bust one, LMC sells all years of them.
J!
Old Oct 20, 2008 | 04:19 PM
petey shoes's Avatar
petey shoes
if they are glued, try using a blow dryer to heat and soften the glue, just don't melt the emblem.
Old Oct 20, 2008 | 04:20 PM
imlowr2's Avatar
imlowr2
Don't pry them off if you have the glued on type, You can snap the emblem or pull paint off the door. Get a piece of fishing string and use it like a saw between the emblem and the door metal going back and forth. The wire string will separate the emblem without ruining the paint or the emblem.
Old Oct 20, 2008 | 05:30 PM
Julies Cool F1
That's a great technique - learn something new everyday. But, how do you get the string under the logo between the mounting studs? Or, aren't there any mounting studs?
J!
Old Oct 21, 2008 | 02:13 AM
F.ROCK's Avatar
F.ROCK
got 'em off. what years are they from? mine doesnt even have door locks.
Old Oct 21, 2008 | 10:46 AM
Julies Cool F1
Hi Rock,
Here's a couple links to the pages in the LMC catalogue. There are a few different styles so take a look and it should tell you what year these are from.
LMC Truck Parts - Page 42
LMC Truck Parts - Page 60
J!
Old Oct 21, 2008 | 10:51 AM
AXracer's Avatar
AXracer
If you are not a fisherman, try using dental floss to cut the emblem glue. Don't have dental floss? Then just whack em with a big hammer just like you fix everything else...
Old Oct 21, 2008 | 10:57 AM
bigwin56f100's Avatar
bigwin56f100
Who uses dental floss when you have "summer teeth" sum are here and sum are there!Kevin Bigwin
Old Oct 21, 2008 | 03:33 PM
petey shoes
yuk, yuk, yuk
Old Oct 21, 2008 | 10:07 PM
Kusto's Avatar
Kusto
I'm actually planning on putting a set of those emblems on mine too in the same location below the windows. I am planning on using 3M adhesive rather than clips that way I don't have to drill holes in the door.
musickerns
1997 - 2003 F150
Nov 6, 2012 11:15 PM
danlee
Dec 16, 2009 10:09 PM
tutiii
1997 - 2003 F150
Sep 17, 2007 09:41 AM
jasonschwenk
Aug 12, 2006 10:13 PM
