More On Wipers....
I had asked last week for info on how to do this and received several responses that were spot on as to how to do it-THANKS!!
When I started doing the removal I slid the latch part away from the shaft area, and gently pulled up on the arm and they both came off very easily.
I immeadiatly (sp) realized that the shafts were much bigger that any previous truck or car that I had ever removed before.
I think this is why the arms came off so easily.
Now for the question and observation: Has anyone else removed their arms and noticed on the back side the groove with either a very hard rubber or soft metal key in there?? (one of mine was missing) I'm thinking I should replace the key if I can find one or 2??
AND it seems rather you have the key or not the arms only will go on 1 way and can't really be "adjusted" like other trucks and cars can, which is ok by me as mine seem to be right in the perfect spot already.
NEXT OBSERVATION: While in the area I noticed that the plastic grille on the cowl on my drivers side (mind you my windsheild has been replaced by the PO) has a kind of clip thing in the middle on the edge closest to the windsheild that appears to be sticking up/out and doesn't look right to me...can anyone tell me how this thing should be installed/attached.THANKS!! & sorry for the long post!
My truck is a LATE '99 F350...may be the earlier trucks have the keyed splines and the later ones don't??
Therefore, you really do not need the woodruff key. Yes, it makes the positioning "singular" in that they can only go in one position. However, the key does not do anything else for you, really, in terms of making the arm more secure. Since the shaft heads are splined, it is the combination of the splines and the spring-loaded latch that slides into position underneath the shaft head that holds the wipers in place both rotationally and vertically. The only purpose for the key is rotational positioning.
Regarding the clip you're talking about and the cowl covers. The covers are held in place with 6 screws each, IIRC. The covers are in two pieces... driver side, and passenger side, meeting in the middle. I cannot remember what the clip is for... perhaps related to the windshield washer hose routing, I think. Regardless, you should not have to do anything with it and can leave it as is.
Hope this helps.
Background.... I recently just got through having to replace the entire wiper arm linkage assembley and motor (now one piece design), and consequently have torn the entire system down and put it back together several times due to a broken linkage component on the new assembley which was not discovered until installation was complete. It's all still fresh in my memory right now.
