Wiper Arm Removal
Old May 10, 2002 | 07:20 PM
lklughers's Avatar
lklughers
Post Wiper Arm Removal
Could someone enlighten me on how to remove the wiper arms on a 67 F100. The manuals say pull the wiper arm back at the pivot and pull arm off the spindle. This is not working in my case. I can find nothing that resembles a catch or key that is holding them on. There is some play so it's not siezed up but it's not coming off either. I do not know if these were the original arms or correct or incorrect replacements. I need to get them off to replace the gaskets. Any insight would be appreciated before I begin to increase the amount of force used to pry them up off the spindle. Thanks Lee.
Old May 10, 2002 | 09:52 PM
Mil1ion's Avatar
Mil1ion
Wiper Arm Removal
The easiest and safest way I've found is to take a pair of needle-nose pliers,A small tack hameer or piece of doweling to be used as a fulcrum,and a rag.
Wrap the rag around the wood to prevent from scratching the paint.
Now place the open needle-nose pliers on either side of the mounting gear,then close them tight and pry up on it.
You might have to do it from two different sides to get it off.
I usually do it from the rounded side.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green] Truck Data Plate Info
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
[/font]
Old May 11, 2002 | 01:08 PM
lklughers's Avatar
lklughers
Thanks Dennis, you were right on. Plus once I knew that force could be applied without damage and there were no trick releases involved I could proceed with some confidence.
Hoping you will check back and realizing your extensive contributions could you possibly suggest someplace I could find a Emergency Brake Bracket for a 67 F100. Local salvage yards have not been helpful.
I thank you again for your help and hope our paths cross again in the future. Lee
Old May 11, 2002 | 02:20 PM
Mil1ion's Avatar
Mil1ion
Wiper Arm Removal
[updated:LAST EDITED ON 11-May-02 AT 03:21 PM (EST)]
If you can't find one,I'll check the 1970 that came into the wrecker on Monday to see if it has one that isn't seized.
[/font
[font color=red]
[/font]
Old May 11, 2002 | 02:22 PM
390fe's Avatar
390fe
Wiper Arm Removal
Old May 7, 2012 | 10:29 PM
CamTom12's Avatar
CamTom12
AAAAAAAAAANCIENT thread,
But I've got a 69 F-250 that looks like it's got a little key thing under the wiper arm. I need to remove and reclock them but don't want to break anything. Is that little peice the catch that holds them on?
Old May 8, 2012 | 09:59 AM
Freightrain's Avatar
Freightrain
Yes. If I recall, use a small screwdriver and push down on it while pulling up on the arm. Been so long since I screwed with the wipers on my '69 I can't say for sure anymore. Been 24 yrs, never replaced them(never goes out in the rain).
Old May 8, 2012 | 11:40 PM
CamTom12's Avatar
CamTom12
I tried that and the clip pulled out from the arm a bit but the arm didn't feel any looser on the spindle. I stopped there so I wouldn't break anything.
Old May 9, 2012 | 08:43 AM
Freightrain
Well, I'll try to go out tonight and look at mine better. I know my '89 has slide lever that unlocks the arm.
Old May 11, 2012 | 09:36 PM
CamTom12's Avatar
CamTom12
Thanks man, I appreciate it!
Old May 16, 2012 | 01:46 AM
CamTom12's Avatar
CamTom12
Freightrain, any luck?
Flat Ernie
Feb 6, 2015 03:28 PM
rhc43
Dec 23, 2014 12:28 PM
slowrollerzcustoms
Jul 14, 2014 12:46 AM
oldblue89
Dec 25, 2009 05:20 PM
Cobra6
Nov 27, 2007 02:28 PM
