dp tuner problem??
Old Oct 17, 2008 | 08:32 PM
ts_stroker's Avatar
ts_stroker
dp tuner problem??
hey guys i just bought dp tuner from itp and i tried to install it today followed step by step instructions but i didn't clean the contacts as good bc i just had a ts chip in it last week....got it all hooked up and the wait to start light doesn't come on so i unhooked everything pulled the pcm and cleaned it a lil more reinstalled and dido same thing but what i don't get is the switch fob lights up and also the instructions say i have 1-3 settings ( what i ordered) and the 4-16 would be the same as 3 but when i turned the key on and it light up it only goes 1-2 no 3-16 so please somebody help me..... thanks.
Old Oct 17, 2008 | 08:43 PM
zx250's Avatar
zx250
Of the next Riffraff East
Congrats on the DP. You're gonna love it. Not sure what to tell you about the WTS light. You may what to pull it one more time and when it's out, disconnect the batteries for a few minutes, turn on the headlights or something to make sure you drain the PCM. Then reinstall making sure chip is fully seated.
As far as the chip read out, mine only reads the files that are in there. Mine stops at 6 for now. Your right, I think my instructions said something about the remaining numbers being the same as the last,
Old Oct 17, 2008 | 08:52 PM
ts_stroker's Avatar
ts_stroker
yea i'm excited but this kinda put a damper on things.....i emailed dennis at itp but so far all he has told me was that its prolly a bad connection but i don't see how it just work last week with my ts...
jhand124's Avatar
jhand124
I believe you blew the 30 amp fuse that controls the pcm, fuel bowl heater etc. To check it it is under your dash in the fuse box.
Old Oct 17, 2008 | 08:56 PM
jhand124's Avatar
jhand124
Ryan, not to be inflammatory but I need some punctuation in your posts, I had to read it 3 times before I knew what you were sayin.
Old Oct 17, 2008 | 08:58 PM
ts_stroker's Avatar
ts_stroker
well thats what i thought to at first...but i can pull the chip and the WTS light comes on and the truck will start...sry bout the punctuation..lol
Old Oct 17, 2008 | 09:03 PM
jhand124's Avatar
jhand124
I would agree with Dennis, it's a bad connection. Double check both pcm and chip.
Old Oct 17, 2008 | 09:08 PM
ts_stroker's Avatar
ts_stroker
i don't see how though? bc its clean and the chip is gettin power bc the fob comes on. but thats what i'm think that i'm missin somthing somewhere so tom. i'll prolly pull the pcm back out and clean it again..and try again and see what happens then if still nothin i don't kno what i'm goin to do.
Old Oct 17, 2008 | 09:14 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
A no Wait to Start Light sounds like a bad connection to me, or you cleaned too much tin off one or more of the contacts. Which is fixable, Jody re-tins your PCM when he does a Live-tuning session, I've seen it first hand at Smokin this year. All you need is a soldering iron and some solder, one pass of solder on each contact and your done. As far as your third tune no showing up on the switch, reprogram your switch, this will help: http://www.dp-tuner.com/documentatio...0indicator.pdf
Old Oct 17, 2008 | 09:26 PM
ts_stroker's Avatar
ts_stroker
i would almost bet thats what i did bc on the bottom side the contacts r silver where on the other they r copper so i'll try that tom. and get back to ya'll and tell ya how it goes and if it works how much difference there is between the ts and dp. THANKS again for all the help and i'll get back to ya'll sometime tom. bc i got a "family" thing goin on so i won't be near a cpu til tom. nite...lol gotta love the fam though
Ryan
Old Oct 17, 2008 | 09:54 PM
jhand124's Avatar
jhand124
Ryan I feel like a 6 yr old trying to read your posts.
Old Oct 18, 2008 | 07:59 AM
big poppa's Avatar
big poppa
Hey Jason, really gettin to yaa huh, lol. Just messin TS. It is tough.
Old Oct 18, 2008 | 08:15 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
They're somewhat tough to follow, that's for sure.
Old Oct 18, 2008 | 09:43 AM
Ponyboychris's Avatar
Ponyboychris
i would almost bet thats what i did bc on the bottom side the contacts r silver where on the other they r copper so i'll try that tom....
This is where your problem is I bet. Too much copper showing is bad.
Old Oct 18, 2008 | 11:37 AM
ts_stroker's Avatar
ts_stroker
to much is bad so i need to rub it down or solder it back on???? i don't remember what they looked like before
