Starting/Flywheel issue.
Old Oct 19, 2008 | 03:42 PM
derekmj64's Avatar
derekmj64
Every once in awhile when i go to start my truck it will make the sound similar to the one where people turn the key when the truck is already running and it makes that whining and grinding noise. I think that there are a couple of teeth missing on the flywheel causing the starter not to grab and make that noise. The starter is also brand new from napa. I am wondering whether you guys think that it is my flywheel or could there be something else wrong and if possible what needs to be done to fix it? I am worried that if its the flywheel it will come to the point where it will keep making the noise and wont start one day. Should I be worried?
Thanks,
Derek
Old Oct 19, 2008 | 03:45 PM
megawatt00's Avatar
megawatt00
To check the teeth on the fly wheel you can remove the inspection plate and look at it, bump the engine and insect the other half. Have you checked the connections on the starter itself, wires, bolts etc?
Old Oct 19, 2008 | 03:54 PM
derekmj64's Avatar
derekmj64
Everything with the started has a good connection. I haven't had the time to pull off the inspection plate. But I will do that as soon as I get back to my parents house when i can do it in the pole barn.
Does anyone know the work involved in pulling the trans to get to be able to remove the flywheel. I know that I am more than capable of doing the job and I really rather not pay a dealer or someone else to do it.
Old Oct 19, 2008 | 03:57 PM
Smokin''s Avatar
Smokin'
Smokin
I find myself wondering if this started after you changed out the starter, or if this was the reason for changing out the starter thinking you may fix the issue?
Old Oct 19, 2008 | 04:06 PM
derekmj64's Avatar
derekmj64
I started hearing this sound so I changed out the factory starter with one from napa and that starter began messing up because it must have had a short since it would draw my batteries down to where they would almost be dead every time I went to start my truck. I took that starter back and this one works fine other than that noise is still there making me think that its the flywheel.
Old Oct 19, 2008 | 04:10 PM
Smokin''s Avatar
Smokin'
Smokin
Ok. I remember back from when I changed my starter, you can actually see the flywheel (as Jim mentioned). You may be able to peek in there and notice any missing teeth.
Old Oct 19, 2008 | 04:42 PM
rbaker6336's Avatar
rbaker6336
I would imagine about 4 1/2 hrs to R&R trans a shop charged me $400
here is a manual https://www.motorcraftservice.com/pu...20/S1OMAIN.HTM
Old Oct 19, 2008 | 05:13 PM
derekmj64's Avatar
derekmj64
thanks for the help.... especially the shop manual that is a very useful tool to have.
muddslinger88
Feb 22, 2011 01:52 PM
lilmama508
Sep 29, 2009 01:17 PM
RynL88
May 4, 2005 12:38 PM
j.foster62
Jan 6, 2004 09:06 PM
fast77
Bronco II
May 13, 2002 09:40 PM
