Flywheel or starter?
Old Sep 29, 2009 | 12:39 AM
lilmama508's Avatar
lilmama508
Here's my problem i have a 2001 expedition and it runs pretty good.just lately i've noticed at times i get in to start it up and it would start fine other times I put the key in to start it and it makes this loud screeching noise like the noise a vehicle makes when you forget it's already running and subconciously you turn the key over again.I was told it may have an aftermarket auto starter in it and somehow engaging,then was told it may be the starter,then told it may be flywheel.I am trying to avoid going to the ford dealer but also want to be steered in the right direction,any suggestions on where i should start? Any advice would be greatly appreciated.Thanks
Old Sep 29, 2009 | 06:28 AM
madsonp's Avatar
madsonp
Sounds like your starter is getting stuck when it's engaged, I'd try a new starter.
Old Sep 29, 2009 | 11:41 AM
alloro's Avatar
alloro
Yes, replace the starter, or at the very least replace the starter drive.
Old Sep 29, 2009 | 01:07 PM
97ExpGuy's Avatar
97ExpGuy
Starter is the easier and cheaper thing to replace. I did mine in an hour's time: that's driving the truck up on ramps, disconnecting the neg battery cable, getting tools out, and actually doing the job. There is a thread on here where someone took photos and some notes that help. Just remember there are three bolts holding the starter on. One is on top and is the "hidden" bolt. Spray them all down with penetrating oil first. Use various 3/8 extensions and you can get right on it without utilizing a universal joint. In fact I think I might have used a 1/2" ratchet and extension because I needed the bigger tool to break bolts loose. I'll search for that thread in the mean time.
Tom
Old Sep 29, 2009 | 01:17 PM
97ExpGuy's Avatar
97ExpGuy
Found it:
https://www.ford-trucks.com/forums/7...xpy-probs.html
Also, I do want to mention I had the EXACT same problem as you were experiencing. I would have the occasional and very random grind. Since I replaced the starter, I have experienced the grinding only once. I think I may have one bad tooth on the flywheel but replacing the starter has helped.
Bill Reich
Nov 10, 2015 10:20 PM
cowboy417
Bronco II
13
Aug 20, 2012 10:57 AM
Aviator2011
Bronco II
May 30, 2012 11:34 PM
BuckHammer
55
Jan 31, 2011 12:59 AM
orthogod1
Dec 28, 2010 06:35 PM
