Electrical help!!!!
Old Oct 18, 2008 | 11:49 PM
RP27G8G's Avatar
RP27G8G
Electrical help!!!!
Went to start my 91 mF250 w/7.3 and nothing. All the lights, etc worked. I then noticed the connection for the glow plug harness was smoking. Turned key off. Same thing a couple more times. Finally I jumped across the starter solenoid and it runs great. Smoke stopped after truck started. Any advice where I should start tracing the million miles of wire? Thanks in advance!
Old Oct 19, 2008 | 08:36 AM
shorebird's Avatar
shorebird
First off check the connection for good contact. Overheating or burning at a connection is usually the result of high resistance due to corrosion or the arcing of a loose connection.
Old Oct 19, 2008 | 09:12 AM
PLC7.3's Avatar
PLC7.3
Look on the right inner fender there is a large black connector or grey connector.... depending on year .....there have been considerable melted connections within these connectors. Most members remove the connector and wire direct...... solder and heat shrink.
andrew4g63
24
Mar 28, 2013 06:43 PM
Brian085
27
Aug 17, 2012 10:51 AM
jarod17
Nevada Chapter
18
Feb 1, 2010 06:35 PM
Mr.G
Modular V8 (4.6L, 5.4L)
Apr 23, 2006 05:16 PM
fordnut1985
Kansas Chapter
42
Jul 11, 2005 09:16 PM
