Negative Camber
Old Oct 17, 2008 | 10:15 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
Negative Camber
I know our PSDs are known to have negative camber and eat up the inside of the front tires, but does anyone know how to help out this situation? Just replaced ball joint 10K miles ago and still doing so. Any help?
Old Oct 17, 2008 | 10:18 PM
Benny2002's Avatar
Benny2002
Camber bushings
Old Oct 17, 2008 | 10:22 PM
robinsonpowerstroke
Originally Posted by Benny2002
Camber bushings
Where do you get them from? How do they work? Are they safe? What do those run for a set?
Old Oct 17, 2008 | 10:30 PM
jhand124's Avatar
jhand124
I have 218K and never have experienced negative camber. I think you are thinking of the OBS F250's with the split axle.
Old Oct 17, 2008 | 10:37 PM
robinsonpowerstroke
Yes my truck is a 250. What is the OBS 250s with a split axle?
Old Oct 18, 2008 | 07:29 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
They can adjust the camber with camber bushings. Your truck should already have them installed but it's possible that it doesn't. Some alignment shops will tell you that there is no adjustment for the camber angle and they're full of crap. It can be adjusted, they just have to know how to do it and not be lazy.
Old Oct 18, 2008 | 10:10 AM
robinsonpowerstroke
Where can you find camber bushings? Dealer, auto parts store?
Old Oct 18, 2008 | 11:32 AM
JethroF250's Avatar
JethroF250
Def an alignment shop. On my 95 OBS diesel I have the stock twin eye beam front axel that pivets in the middle. Usually when you experience this it is ***** joints but in your case I would put monney on bushings. My truck had alot of positive camber so it was eating up the outside. Took it to my friends at the alignment shop that my buddies own and they put bushings in. Bam problem solved. And it only cost me 157 to 175 to get them put in at the shop. They said that was standard price. I hop this helps Robinson
Old Oct 18, 2008 | 12:23 PM
DCSpecial's Avatar
DCSpecial
Have you had a professional alignment done?
There are cams around the upper ball joints that can be swapped to adjust caster and/or camber.
Did you do the ball joints yourself?
Here's an example of a stock cam vs. a cam designed to give more positive caster:
As for what cam if any you need.....you'd have to have it put on an alignment rack to see what your current settings are.
Old Oct 18, 2008 | 03:00 PM
fireLt.'s Avatar
fireLt.
Must be done at an alignment shop. There are several different degrees of bushishings from .25 to 1.5. They can be used to adjust camber, caster, or a combination of both. I have done lots of these on Super Duties. Usually .25 to .75 degrees will fix the problem. I charged 1hr. labor per side to install the bushings.The bushings run about $35 each. It is a little spendy but so are tires and the truck will drive MUCH better. Any good alignment shop should be able to help. Watch out for shops that do a "toe and go" special. The spec on the SD should be +.25 to -.25 camber with no more than .50 difference from side to side. Caster should be around -5.0 +or- 1.0 no more than .5 difference from side to side. I am pulling that from memory and its been a couple years so it may be off some. Always ask for a print out of the before and after readings. Hope this helps.
Old Oct 18, 2008 | 07:04 PM
DCSpecial's Avatar
DCSpecial
Actually you can get larger bushings than 1.5*......the ones on the right in the picture I posted are 2.25* caster.
Old Oct 18, 2008 | 07:48 PM
fireLt.'s Avatar
fireLt.
Just proves after being out of the biz for 6 years I don't have it all memorized anymore.
Old Oct 18, 2008 | 08:12 PM
DCSpecial's Avatar
DCSpecial
They'll be going on my 07 F-350...hopefully next week.
Cduncf150
1997 - 2003 F150
Jan 25, 2017 08:07 PM
GraysonB97
1997 - 2003 F150
Jan 27, 2016 01:28 PM
boosteddsm
16
Aug 9, 2011 07:34 AM
FritzBlitz
Apr 21, 2006 08:59 AM
Cor
Aug 26, 2004 04:07 PM
