Sponsored by: Real Truck
Engine code help
Old Oct 17, 2008 | 06:19 PM
Gmeanie's Avatar
Gmeanie
Engine code help
I had the codes pulled for my 2001 f250 5.4 V8 because the Service Engine light kept coming on.
They read P1151 P1152 - Manufacturer control Fuel air metering.
My haynes repair manual doesn't even show these codes?
I told the kid what my truck was maybe he screwed it up?
If these codes are right I have no clue what this even means so any help there would be great.
Old Oct 17, 2008 | 06:26 PM
projectSHO89's Avatar
projectSHO89
Probably time for a new upstream O2 sensor on the passenger side.
Steve
Old Oct 17, 2008 | 06:54 PM
PowerStrokeHD's Avatar
PowerStrokeHD
P1151 - Lack of HO2S-21 Switch, Sensor Indicates Lean
Detailed Description...
A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when fuel control system no longer detects switching for a calibrated amount of time.
Possible causes...
Electrical:
Short to VPWR in harness or HO2S.
Water in harness connector.
Open/Shorted HO2S circuit.
Corrosion or poor mating terminals and wiring.
Damaged HO2S.
Damaged PCM.
Fuel System:
Excessive fuel pressure.
Leaking/contaminated fuel injectors.
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Vapor recovery system.
Induction System:
Air leaks after the MAF.
Vacuum leaks.
PCV system.
Improperly seated engine oil dipstick.
EGR System:
Leaking gasket.
Stuck EGR valve.
Leaking diaphragm or EVR.
Base Engine:
Oil overfill.
Cam Timing.
Cylinder compression.
Exhaust leaks before or near the HO2S(s).
P1152 - Lack of HO2S-21 Switch, Sensor Indicates Rich
A HEGO sensor indicating rich at the end of a test is trying to correct for an over-lean condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Possible causes...
Electrical:
Damaged HO2S.
Damaged PCM.
Fuel System:
Induction System:
Vacuum leaks.
PCV system.
EGR System:
Leaking gasket.
Stuck EGR valve.
Base Engine:
Oil overfill.
Cam Timing.
Old Oct 18, 2008 | 09:33 PM
Gmeanie's Avatar
Gmeanie
So the code pretty much means anything could be wrong with my truck?
Possible causes...
Electrical:
Damaged HO2S.
Damaged PCM.
Fuel System:
Induction System:
Vacuum leaks.
PCV system.
EGR System:
Leaking gasket.
Stuck EGR valve.
Base Engine:
Oil overfill.
Cam Timing.
Possible causes...
Electrical:
Damaged HO2S.
Damaged PCM.
Fuel System:
Induction System:
Vacuum leaks.
PCV system.
EGR System:
Leaking gasket.
Stuck EGR valve.
Base Engine:
Oil overfill.
Cam Timing.
Old Oct 18, 2008 | 10:21 PM
PowerStrokeHD
I was asking my self the same question. I am not much of a expert when it comes to gassers, but I figured I could at least look up the codes. They are usually remotely helpful, but in this case not so much.
At this point Steve's suggestion looks the best...
Old Oct 18, 2008 | 10:41 PM
PowerStrokeHD
You can find more diagnostic information at the link below, but it does not look like there is much you can do without the proper diagnostic equipment...
On Board Diagnostics II
Old Oct 20, 2008 | 01:46 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Since it's two codes, basically mutually exclusive:
P1151 Lack Of HO2S-21 Switch Indicates Lean (Ford)
P1152 Lack Of HO2S-21 Switch Indicates Rich (Ford)
Both for bank 2.
However, reading a few Google hits for issues with these codes for Fords, it actually might be the MAF. Clean it and reset the computer and see if they come back.
Bank 2 is the driver's side. If the codes come back after cleaning the MAF, and you have no vacuum leaks, I'd change the driver's side O2 sensor.
Old Oct 22, 2008 | 11:27 AM
Gmeanie's Avatar
Gmeanie
Will try these tips out been sick so haven't had a chance to get out there.
The idle started acting weird every once in awhile if that helps any.
Old Oct 23, 2008 | 08:39 AM
projectSHO89
Replace the upstream sensor on the DRIVER'S side (I previously indicated the wrong side - probably didn't read closely enough).
You have two codes that directly contradict each other. That is almost always an indication that the sensor has gone south.
Steve
i eat hybrids
May 20, 2017 10:15 PM
95350PS
21
Jul 2, 2012 09:13 PM
PoPs 03DEX
Aug 10, 2011 04:26 PM
irishguyincc
General Automotive Discussion
Jun 28, 2010 12:20 PM
guidry23
Jun 16, 2009 10:24 PM
