Engine code help
They read P1151 P1152 - Manufacturer control Fuel air metering.
My haynes repair manual doesn't even show these codes?
I told the kid what my truck was maybe he screwed it up?
If these codes are right I have no clue what this even means so any help there would be great.
Detailed Description...
A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when fuel control system no longer detects switching for a calibrated amount of time.
Possible causes...
Electrical:
Short to VPWR in harness or HO2S.
Water in harness connector.
Open/Shorted HO2S circuit.
Corrosion or poor mating terminals and wiring.
Damaged HO2S.
Damaged PCM.
Fuel System:
Excessive fuel pressure.
Leaking/contaminated fuel injectors.
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Vapor recovery system.
Induction System:
Air leaks after the MAF.
Vacuum leaks.
PCV system.
Improperly seated engine oil dipstick.
EGR System:
Leaking gasket.
Stuck EGR valve.
Leaking diaphragm or EVR.
Base Engine:
Oil overfill.
Cam Timing.
Cylinder compression.
Exhaust leaks before or near the HO2S(s).
P1152 - Lack of HO2S-21 Switch, Sensor Indicates Rich
A HEGO sensor indicating rich at the end of a test is trying to correct for an over-lean condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Possible causes...
Electrical:
Damaged HO2S.
Damaged PCM.
Fuel System:
Induction System:
Vacuum leaks.
PCV system.
EGR System:
Leaking gasket.
Stuck EGR valve.
Base Engine:
Oil overfill.
Cam Timing.
Possible causes...
Electrical:
Damaged HO2S.
Damaged PCM.
Fuel System:
Induction System:
Vacuum leaks.
PCV system.
EGR System:
Leaking gasket.
Stuck EGR valve.
Base Engine:
Oil overfill.
Cam Timing.
Possible causes...
Electrical:
Damaged HO2S.
Damaged PCM.
Fuel System:
Induction System:
Vacuum leaks.
PCV system.
EGR System:
Leaking gasket.
Stuck EGR valve.
Base Engine:
Oil overfill.
Cam Timing.
At this point Steve's suggestion looks the best...
On Board Diagnostics II
P1151 Lack Of HO2S-21 Switch Indicates Lean (Ford)
P1152 Lack Of HO2S-21 Switch Indicates Rich (Ford)
Both for bank 2.
However, reading a few Google hits for issues with these codes for Fords, it actually might be the MAF. Clean it and reset the computer and see if they come back.
Bank 2 is the driver's side. If the codes come back after cleaning the MAF, and you have no vacuum leaks, I'd change the driver's side O2 sensor.
The idle started acting weird every once in awhile if that helps any.
You have two codes that directly contradict each other. That is almost always an indication that the sensor has gone south.
Steve
