Does anyone know where the PCM sees water temp? I have the scan gauge and on a cold start the temp reads around 190 slowly climbs to 236 and then the t-stat opens and it instantly drops to aroung 180 climbs to 203-205 and stays there. I thought this was odd that the temp would climb so high but I was assuming the temp sensor was the one on the water pump for the dummy gauge.
The proplem I have had today and yesterday was that the water would warm up to 233 and stay right there. The stat is not opening (no flow or heat through the upper radiator hose). Also the fan runs continuously-even on a cold start 50 degrees outside. I can make the dummy gauge move and got the engine hot(moved from the "r" to the "a" in normal, but the scan gauge only moved between 232 and 235.
I have to pick up a machine tomorrow(around 9-10,000#) and this has me worried. Any thoughts?
Thanks
Being that the OBD2 scan shows an erratic coolant temp on the PSD.
It has stopped me from trying to use a 5v input to the pcm.
The PCM has a pin for it with no wiring to the pin.
Allway's thought something would go POOF!!!
I wonder what the scan gauge is reading then? It is labeled water temp. I have had it on for the last two months or so and it is consistent on every start up leveling off at 203 degrees. They screwed up programmingthe gauge from the start and it still wont read the icp pressure I would have assumed it was water because of the 203 stat. Does yours do anything TJ?
Another though--could it be oil temp? I just put a resistor on the eot sensor yesterday and that is when it started acting up. oil and water usually run close to the same don't they?
If I set mine up to view water temp it will just display the last number or no number. it just doesn't work so I haven't looked at it in a long time. Could be showing oil temp just labeled wrong. With my 203 stat in though my oil temps rarely get to 195. Coolant temps run 195-200, towing close to 210.
