Sponsored by: Real Truck
captain chairs
Old Oct 15, 2008 | 12:52 AM
995.4SD's Avatar
995.4SD
captain chairs
So i have a 99 superduty XL model with the bench seat. i liked the seat until my puppy (at the time) chewed out the foam right in the corner that i sit in while i was in the store. i made a temp sew job with some fishing line, but i would like to upgrade to an XLT seat, or the lariat bench seat...just something with armrests and a center console. i will probably be getting it off ebay, maybe junkyard if they have anything. my question is what years will fit, and since mine is the XL are the XLT or lariat going to bolt down differently because of the more adjustments or do they all bolt down the same?
thanks for the help!
Old Oct 15, 2008 | 01:00 AM
jake00's Avatar
jake00
they should all bolt the same, and i Think 99-07 should be a exact match
Old Oct 15, 2008 | 01:01 AM
995.4SD's Avatar
995.4SD
ok, just did some searching on ebay and one ad that was selling lariat seats said if you have integrated seat belts they will not fit...what are integrated seat belts?
Old Oct 15, 2008 | 01:16 AM
995.4SD's Avatar
995.4SD
also one more thing, if i buy power seats, will i be able to wire them to make them work even though mine are manual, or is it more of a pain than it is worth? seems to be a LOT more power seats than manual.
Old Oct 15, 2008 | 12:26 PM
madjak's Avatar
madjak
Integrated seat belts are part of the seat. They retract into the seat. Yours on the 99 XL are mounted to the frame and just feed through the seat.
Old Oct 15, 2008 | 07:19 PM
06silvercrew's Avatar
06silvercrew
You need what my XLT has. 60/40 cloth with a fold down center console with two cupholders. They are manual so no wiring. That would be the easiest swap and they are comfy as hell.
Old Oct 15, 2008 | 10:50 PM
995.4SD's Avatar
995.4SD
sweet, thanks for the replies...and the search begins!
hivoltj
1978 - 1996 Big Bronco
May 13, 2014 12:20 PM
M*A*S*H
Jun 6, 2013 10:47 PM
Jakel452
Nov 6, 2012 11:01 AM
Ann H.
2009 - 2014 F150
Sep 3, 2010 04:38 PM
