Easy Performance
Old Oct 18, 2008 | 04:46 PM
Rockstone's Avatar
Rockstone
Originally Posted by hairyboxnoogle
yea, get a cam, carb and intake. Also, one benifit of going with an aluminum intake on a FE, is you save like 40lbs or more. Also, intakes are not hard to change at all. Then later, if you want, drive it down to a shop and have em install the cam. If you dont know anyone who is sure on how to break in a cam, have a shop do it. Theyll know what to do, and if they dont, well they have to warranty it. But the things i listed, and your exaust, is a very well rounded mild build. It will run great, get good mileage and last forever. Anything over these minor things can start cutting down on drivability and reliability. But your next steps would be, head work, and some slugs. (aka=pistons)
Oh, as far as cam choice goes, call summit or jegs, or conp or crane or someone, and tell them what you have, theyll suggest a cam for you.
Intakes on FE's are a little more involved than other Ford engines. You have to remove the rocker arm assemblies and push rods, but it isn't to bad.
Old Oct 18, 2008 | 08:37 PM
gearhed1971's Avatar
gearhed1971
also make sure you step up ignition timing to 10 -12 degrees before tdc if you haven't already-factory setting is at six.I had two shops check my timing before I was set up to do my own work,and both set the timing at 6.Check FE faq-
Old Oct 18, 2008 | 09:09 PM
peganit2's Avatar
peganit2
and I'd advise a hoist or a cherry picker to get the iron manifold off. It's a backbreaker. I know, I changed one when I was younger. It has got to be the heaviest common gas engine intake around.
Old Oct 18, 2008 | 09:44 PM
Pud12343's Avatar
Pud12343
alright, thanks guys! any more suggestions would be great too, but i dont think ill have trouble gettin the manifold off....im a slightly big guy haha played football in highschool.....6'4 285
Old Oct 18, 2008 | 09:49 PM
peganit2's Avatar
peganit2
Not sure if the same is true on FE's, but 460's respond real well to recurving the distributor. They "feel" a lot quicker, for less then $5.00.
Old Oct 19, 2008 | 02:03 AM
Pud12343's Avatar
Pud12343
and how might i go about doing that?
Old Oct 19, 2008 | 04:09 PM
peganit2's Avatar
peganit2
Go to; www.reincarnation-automotive.com and look for the tech article on distributor recurving. It's listed in the products index
Your Fe may not have the duraspark. You can get one or your old points type can be recurved itself.
Old Nov 10, 2008 | 04:06 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Sorry if the title is a little misleading lol, im just wondering what kind of performance upgrades would be the best for my 390 2v. Im not talkin about like a stroker kit or anything like that....just things that i can install and set up without completely dis assembling the engine.
thanks!
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
ron2681
1978 - 1996 Big Bronco
22
Feb 2, 2014 06:28 PM
94 smokin stroker
Jan 25, 2011 02:30 AM
Snow_Freak
Dec 5, 2007 10:11 AM
keith Ruge
2004 - 2008 F150
Apr 28, 2006 11:32 PM
ckb2steelers
Modular V10 (6.8l)
Jan 14, 2006 01:37 PM
