Offroad & 4x4
axle type?
Old Feb 27, 2000 | 08:47 PM
cajunbuck's Avatar
cajunbuck
axle type?
i have a 94 F150 XLT 2wd auto. I was wondering what type of axle i have on my truck. i looked on the axle and it said H9 and had the following numbers: S947F 3L55 88 4F13. I am planning on putting in a limited slip locker, but im not sure if this is the best route to go. I plan on a 6" superlift suspension lift and 33"x12.5 BF all-terrain ko's. i want to do some non-serious fun mudding and need to know if this is a good set up for what i have in mind. any help would be great and also i am conserned about money so am air locker is pretty much out of the question (im a college student if you follow me) Thanks
Old Feb 28, 2000 | 01:46 AM
fordmando's Avatar
fordmando
axle type?
It's most likely a Ford 8.8 rear end. Doeas it have a removable rear cover on the diff? Then its a 8.8.
fordmando
78 F-150 4x4 400 4 on floor
86 Nissan 300ZX
George
<a href=""></a>
Old Feb 28, 2000 | 05:15 PM
anne's Avatar
anne
axle type?
thanks for your help...i figured it was an 8.8. do you happen to know what spline that is? i want to put in a locker, but im lost on all the different spline numbers. thanks again
Old Feb 28, 2000 | 06:20 PM
Eddie's Avatar
Eddie
axle type?
"H9" = 3,800-lb. weight capacity, 3.55-to-1 ratio,
open rear. One of the cheap, "lunch box lockers" would be the way I'd go.
Eddie
Old Feb 29, 2000 | 12:42 AM
H8monday's Avatar
H8monday
axle type?
Your rear axle should be a 31 spline. Its a good solid axle,I would suggest a tratech gearless locker.They are fairly smooth, have good traction indexing, affordable, easy to install, and come from a very reliable company.Later,
Jeff
Old Feb 29, 2000 | 01:28 PM
cajunbuck's Avatar
cajunbuck
axle type?
i really appreciate all of your info. thanks for helping me out with such confusing and tedious stuff!
Old Mar 5, 2000 | 05:03 PM
Matt's Avatar
Matt
axle type?
Old Aug 4, 2000 | 12:53 AM
hoss's Avatar
hoss
axle type?
30 SPLINE!! If you've got 31 splines your lucky, because they came with 30 from the factory, even on the tow package.
FordMuddin'
Aug 7, 2010 09:08 PM
MOWS 4 U
Sep 6, 2009 07:38 PM
Soilman
Offroad & 4x4
15
Jun 26, 2007 12:06 PM
1975Ford
34
Dec 16, 2005 01:44 PM
gittinwidit
All Things Towing
Apr 30, 2004 10:17 AM
