front axle lockers
Old Oct 24, 2005 | 02:52 PM
1975Ford's Avatar
1975Ford
Talking front axle lockers
I have a 1976 Ford F150 4x4 with 3:73 front and rear gears. The rear gears are Limited Slip. I am in search of any stories or comments or suggestion on what type of locker would work best on my Four by 4.
Old Oct 24, 2005 | 03:33 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
tire size??? what kinda wheeling do you plan on?? what kind of budget?? give us some details
Old Oct 24, 2005 | 03:53 PM
Mil1ion's Avatar
Mil1ion
Hanging out in this forum below should help you.
https://www.ford-trucks.com/forums/f...splay.php?f=63
Old Oct 24, 2005 | 03:54 PM
1975Ford's Avatar
1975Ford
Current tire size are 31" x 10.50" on 15" rim.
When four wheeling the truck will be doing some mud bogging, some rock krawling, and snow wheeling. But want some type of locker that's durable.
It started with a front axle housing seal leak. It turn out the axle seal needing replacing was in the axle and I had to remove the front gears. I thought for a moment, What greater opportunity to replace the front axle with some type of locker. Currently with the front axle gutted and at a point where I am going to order some type of locker.
Old Oct 24, 2005 | 07:13 PM
MBBFord's Avatar
MBBFord
The lock right locker($250) would be pretty good for you, but if you have the money and want to go through a little more trouble get the Detroit locker($500).
Old Oct 25, 2005 | 08:25 AM
77300i6's Avatar
77300i6
If you got the funds, I say go ARB air locker. Full lock engaged, open diff for hiway driving when dis-engaged.
Old Oct 25, 2005 | 11:28 AM
jpb222's Avatar
jpb222
locker
I highly recomend an aussie locker for the front. I put one in my 74 bronco and couldn't be happier with it.
They are durable and don't rachet as much as some of the competition.
Take note that is you drive it on the road in the snow, it takes dome getting used to unless you keep one hub unlocked.
Old Oct 25, 2005 | 02:22 PM
1975Ford's Avatar
1975Ford
The rear gears has the factory limited slip.
The Front gears is where I plan on putting the lockers.
How do the Detroit E-Z lockers compare to the Powertrak lock right lockers, as far as durability and fourwheeling?
jpb222, What makes the aussie locker unpredictable in the snow? Who sells these lockers. Is it a spool locker?
Old Oct 25, 2005 | 03:36 PM
jpb222's Avatar
jpb222
locker
Any locker or spool in the front drive axle is unperdictable in the snow.
Aussie locker is made by torq masters.
It is an automatic, lunchbox style locker just like the powertrax and e-z locker but it unlocks easier and has less play than the others in my experience.
Old Oct 25, 2005 | 05:11 PM
ivanvel's Avatar
ivanvel
Here you go: http://www.offroadlockers.com/home.p...71a/c298/.html
Old Oct 25, 2005 | 05:15 PM
1975Ford's Avatar
1975Ford
ivanvel, seems like a price that's hard to refuse. $229.99 for aussie lockers.
Old Oct 25, 2005 | 07:18 PM
MBBFord's Avatar
MBBFord
I have to admit the Aussie lockers sounds great(even alittle better than the lock right), and I would go with that, except for the fact that I always see Lock Rights go on ebay for about 100 bucks.
Old Oct 25, 2005 | 10:59 PM
ivanvel's Avatar
ivanvel
Yeah i would do the same.. can't go wrong with the Aussie, expecaially for the price!
Old Oct 26, 2005 | 12:26 PM
1975Ford's Avatar
1975Ford
Do the Powertrax Lock Right Locker make popping noise on the front end, when four wheeling, with the front wheels turned? Or when does it make the pop noise? Does it make it frequently?
Old Nov 3, 2005 | 10:59 AM
1975Ford's Avatar
1975Ford
The new axle housing seals are one piece. The old seal I removed were two piece. Are the one piece any better then the two piece?
Any suggestion on an easy way to install these new axle housing seals?
I was thinking of a very long extension with a socket that match the seals, and pounding the new seal with the extensions through the axle housing.
