A/C Controls
Old Oct 13, 2008 | 08:00 PM
mikeh98's Avatar
mikeh98
A/C Controls
Why is it that everytime I start my 2004 F-150 SCREW Lariat I have to select the recirculate button for max a/c? Is there something I'm missing with this automatic climate control in the manual mode? Thanks.
By the way I think that it is strange to see Hummer ads on a Ford Truck forum.
Old Oct 13, 2008 | 10:55 PM
Jarma36's Avatar
Jarma36
if i am understanding your question correctly, max a/c works by recirculatiing the air already in the truck therefore the recirculate button lights up
Old Oct 14, 2008 | 04:51 PM
mikeh98's Avatar
mikeh98
Yep, max a/c works when you select the recirculate mode of operation. It just doesn't stay "engaged" so that the next time you start the truck it is functioning. On the system I have the button doesn't light up but an icon on the display does.
Thanks to whomever placed the H3 ad on my post. Real classy.
Old Oct 14, 2008 | 05:05 PM
Jarma36's Avatar
Jarma36
i see, that is normal, max a/c shuts off when u turn the truck off and you have to put it back on
Old Oct 14, 2008 | 05:24 PM
air1jpg's Avatar
air1jpg
I am assuming that you have the ETAC climate control, but the unit automatically uses MAX A/C until the set temperature is reached or at least close to it. It will automatically switch to "normal" A/C after that. The MAX or recalculate button is there so if you want to manually set it to recalculate and have it run that way all the time.
Old Oct 15, 2008 | 06:57 PM
mikeh98's Avatar
mikeh98
Thanks. I usually run the climate control in manual not automatic so I guess it's something I have to live with.
tr2162
Jun 1, 2025 12:55 PM
79fordf250pickup
Jul 6, 2012 12:36 PM
mpruitt
Jan 29, 2012 08:51 PM
benavidesjr
2004 - 2008 F150
Feb 8, 2010 09:37 PM
tigerarch
2004 - 2008 F150
Feb 21, 2008 12:07 PM
