Digital A/C control
Old Feb 20, 2008 | 07:56 PM
tigerarch's Avatar
tigerarch
Digital A/C control
Has anyone replaced the manual A/C controls with the digital climate control one? Is it just a plug and play replacement, or are other parts needed? I know it needs temperature sensors, but are they already there or will I have to add them? Thanks.
Old Feb 20, 2008 | 08:20 PM
Deluxe05's Avatar
Deluxe05
I have yet to see/hear of anyone successfully making this conversion. This is due largely to the fact that no one has successfully reverse engineered the full system to figure out all of the required components.
Some of the previous discussions regarding this conversion include talk about needing an entire HVAC core, the EATC control unit (or head unit, as it is often called), whatever mechanisms control the damper doors (many arguments on this revolving around electric motors vs. vacuum), and then several theories on whether or not the PCM itself plays a role in all of this.
Best I can offer is to do some searching, and a hearty good luck.
Old Feb 20, 2008 | 08:45 PM
I_am_fishbait's Avatar
I_am_fishbait
Digital A/c Conversion.
I was interested in this upgrade also. I called several of the dealerships around the area (just to get a consistant answer) and was given a 100% you can't do it without ripping out the whole system and rebuilding it with the digital stuff...
Old Feb 20, 2008 | 08:53 PM
tigerarch's Avatar
tigerarch
Well, that sucks. I guess I'll just stick with the manual controls. Thanks.
Old Feb 21, 2008 | 12:07 PM
berry1234's Avatar
berry1234
No, it is not a plug and pray operation. Many items to replace, etc. Not worth the hassle.
dan.alger
Jun 1, 2012 12:37 PM
nagetech
Oct 7, 2011 01:14 PM
ajorgensen
Dec 15, 2007 07:06 PM
Mike SVOR
6.4L Power Stroke Diesel
Sep 22, 2007 06:24 PM
Skersion
Aug 19, 2007 06:33 AM
