Pulling a power steering pump?
Old Oct 13, 2008 | 11:06 AM
westcoastslider's Avatar
westcoastslider
My power steering pump was missing a bolt and has been eating belts. It feels like it has a lot of end play in the pulley shaft.
Looks like the pulley is a pull off press on type of deal. Does anyone have a good suggestion where to get the puller?
Any special suggestions?
Old Oct 13, 2008 | 11:24 AM
c00nhunterjoe's Avatar
c00nhunterjoe
otc makes them, or you can rent it from autozone,. there is a puller and an installer
Old Oct 13, 2008 | 11:26 AM
westcoastslider
Thanks Joe,
I'll probly go rent one from auto zone. Just tell them it's for the PSD. Or is it just a generic puller?
Old Oct 13, 2008 | 11:29 AM
paddler's Avatar
paddler
Power steering pump
I think I just used a generic 2-jaw puller. I recollect the pump shaft is internally threaded, so you put a bolt and washer on the shaft and tighten to press on the pulley. I think I did that on the truck, with the belt on the pulley so the shaft didn't spin.
Overall, pretty easy job. Use a long breaker bar on the belt tensioner... makes it easy to move the tensioner with one hand and get the belt on or off with the other.
While you're at it, check your vacuum pump. It's next to the power steering pump. If the vacuum pump goes, so does your brake assist. Mine cracked between the pulley bearing and the pump body. I recollect it was pretty cheap and replacement is easy, so it may be worth your while to replace it while you're doing the power steering pump.
Old Oct 13, 2008 | 11:31 AM
ono_55's Avatar
ono_55
Harbor frieight has them for about 25.00 you can use them for your vac pump also they work very well for the price.
Old Oct 13, 2008 | 11:53 AM
c00nhunterjoe
you can do it without the belt on, its a double nut tool, if that makes any sense to you, and the installer is just the opposite
Old Oct 13, 2008 | 12:05 PM
westcoastslider
Don't guess I know it by that name, would this be different than the jaw 2-puller that paddler was talking about?
Old Oct 13, 2008 | 02:20 PM
c00nhunterjoe
i meant that the tool uses the double nut theory to keep it from spinning off, it locks against itself so you dont have to have the belt on to keep anything from spinning
Old Oct 13, 2008 | 03:54 PM
Action4478's Avatar
Action4478
Puller & installer pic...
Old Oct 13, 2008 | 05:50 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Pictures are worth a thousand words. Reps sent.
Old Oct 14, 2008 | 07:03 AM
westcoastslider
OK Joe, I see what you mean by a double nut tool.
Yeah, I saw that picture in the post the "miss" had about her vacum pump. I'm sure that's the correct tool to use but I'm kinda one of those get it done with what you got guys. Theres a autozone five miles from me and they rent a three jaw puller for $30.
Using the jaw puller a brobly will need the belt on to hold the pulley in place.
Old Oct 14, 2008 | 08:48 AM
Hussler's Avatar
Hussler
It takes an incredible amount of force to remove that pulley. I would think a 3 jaw puller would just bend the pulley and destroy it. For 30 bucks you should be able to purchase the proper tool.
Old Oct 14, 2008 | 09:30 AM
ono_55's Avatar
ono_55
Like Hussler said you will destroy the pulley, it's not worth the trouble.Just get the right tool for the job.
Old Oct 14, 2008 | 09:39 AM
Action4478's Avatar
Action4478
What he said ,,,
AZ most likely rents out the proper one also...
Old Oct 25, 2008 | 11:10 AM
MissIndependent's Avatar
MissIndependent
What he said ,,,
our local AZ charged me $48 to walk out with the tools...but I got a 100% refund when I took them back!
tweedking
Jan 15, 2017 08:22 PM
mxer0022
Sep 13, 2016 09:58 PM
giwdul
Dec 16, 2015 11:28 PM
Obtuse1
May 16, 2004 02:34 PM
Scavenger
Dec 31, 2001 03:07 PM
