injector wiring harness
Old Oct 10, 2008 | 09:35 PM
F350-6's Avatar
F350-6
The driver side is the one with the 42 pin connector. It's the square box with a bolt in the middle that looks like it's bolted to the valve cover. I just pulled the VC off the passenger side on my wife's truck tonight. Only takes 2-3 hours to get it off, retorqe the rocker arm pedestals to 20 ft - lbs, injector hold down bolts to 120 in - lbs (3 were loose almost a 1/2 turn ), clean things up a little, grind a quarter down and stick it in, then put it all back together. Gonna do the drivers side tomorrow.
I agree with not driving it until you get this fixed. That trip will take a loooooong time if you try to make it on only 4 cylinders.
holdendaniels
Mar 20, 2016 06:04 PM
99F350bigorange
Jan 27, 2011 10:41 PM
5.0 Junkie
Aug 8, 2009 10:13 PM
aocabrown
Feb 13, 2008 05:34 PM
