Fuel injector harness
Old Jan 27, 2011 | 06:53 PM
99F350bigorange's Avatar
99F350bigorange
I have a 1999 f350 7.3 and my drivers side fuel injector harness is vibrating unplugged like every two or three months. It comes unplugged on the inside of the valve cover of course and Its getting annoying having to take it apart just to push the connectors togethor and then put it back togethor. Anyone have any ideas on whether or not I need to replace the valve cover gasket where it plugs in or the fuel injector harness itself?
Old Jan 27, 2011 | 06:57 PM
sandmanf250's Avatar
sandmanf250
unpluging
would a small zip tie help?
Old Jan 27, 2011 | 06:59 PM
99F350bigorange
I thought about it but I dont know where I would zip tie it to. I also have to be careful since its inside the valve cover I dont want anything coming off and getting inside the engine.
Old Jan 27, 2011 | 08:04 PM
sandmanf250
zip tie
plastic won't hurt anything.good luck
Old Jan 27, 2011 | 08:05 PM
F350-6's Avatar
F350-6
You know we have a 99 - 03 7.3 diesel section located a little further down the main forum listing. You should stop in there and check it out.
You're options are to buy an updated harness from Ford or International. Buy and install the retaining clips they sell to help keep the plug together, or make your own shim and do it yourself. The key will be to make sure you don't have any broken tabs on the connector under the valve cover before deciding which way to proceed.
Also while you're under there. You should really consider re-torquing your lower injector hold down bolts and the rocker arm pedestal bolts.
Read this: https://www.ford-trucks.com/forums/7...rs-manual.html
Old Jan 27, 2011 | 08:06 PM
BigAlsPSD's Avatar
BigAlsPSD
Go to the 7.3 forum and search for the 50cent mod. It is a ground down quarter to hold the clips in place, or the ford dealer sells retaining clips that they added to their updated harnesses in '02
https://www.ford-trucks.com/forums/8...ck-shakes.html
Old Jan 27, 2011 | 08:09 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Jan 27, 2011 | 10:41 PM
99F350bigorange
Will do thanks everyone.
Lsouth5167
Aug 29, 2016 05:54 PM
82F100SWB
Feb 2, 2016 12:10 AM
shakenbake254
Jan 5, 2016 05:48 PM
dcelrod
Jun 18, 2015 09:30 PM
drypowder
18
Jun 17, 2012 03:35 PM
