injector wiring harness
Old Oct 10, 2008 | 06:56 PM
7.3mule's Avatar
7.3mule
my light has been coming on and then off the last coupleof weeks so i decided to get a diagnostic done on her at the dealer, he comes and tell me i need to replace my injector harness, didnt think about gettin code print out, but my question is this.... would it be wise to take it to charlotte this weekend or should i leave it parked, its running fine, no major smoking, just the light every now and then.
2002 lariat
Old Oct 10, 2008 | 07:00 PM
mongo75's Avatar
mongo75
Well, the worst that could happen is anywhere from rough running to a dead engine. Did he say if it's the actual thick harness from the PCM to the block, or the harness under the valve cover? Either way, it sounds like you might have a wire that's worn thorugh the insulation and is occasionally grounding out. If that's the case I'd look for it myself and fix it instead of getting gouged by the dealership for something simple.
Old Oct 10, 2008 | 07:02 PM
Kwikkordead's Avatar
Kwikkordead
Fix it before you drive it that far. It might be good now, but if that inner plug comes out one more millimeter then you have a big problem and you will be far from home.
Old Oct 10, 2008 | 07:03 PM
megawatt00's Avatar
megawatt00
I agree with what Danny said. I would look at where the wiring goes into the valve cover and look for signs of chaffing there. It could also be that the connector under the cover is loose.
Old Oct 10, 2008 | 07:07 PM
danskool's Avatar
danskool
Go Bills !
I also agree. Fix it or leave it parked. Broke down far from planet earth sucks.
Old Oct 10, 2008 | 07:11 PM
7.3mule's Avatar
7.3mule
he said it was the harness under the covers, there is a quick fix to this? or is it a major job?
Old Oct 10, 2008 | 07:14 PM
danskool's Avatar
danskool
Go Bills !
FDDTS - 7.3L UVC Harness Retainer Clips
Good time for the .25cent mod.
Old Oct 10, 2008 | 07:16 PM
mongo75's Avatar
mongo75
The hardest part about the UVC harness is getting the damn valve cover off, and if you're lucky, it's the driver side 'cause the pass side sux!! More than likely the connector clip broke from vibration, or it just rattled loose. You can slap it back together, or throw a new one in there if you got extra cash laying around...
Old Oct 10, 2008 | 07:27 PM
megawatt00's Avatar
megawatt00
Here is the thread that Chris posted the pics of Dan's quarter mod. See post #11
https://www.ford-trucks.com/forums/7...rs-manual.html
Old Oct 10, 2008 | 07:29 PM
7.3mule's Avatar
7.3mule
it seems the light comes on mostly when the engine goes into overdrive(drops to low rpm) damnit i guess i'll take the ol' ladys car to charlotte.
Old Oct 10, 2008 | 07:34 PM
danskool's Avatar
danskool
Go Bills !
There you go jim, you had it saved. Knew someone would.. I was digging through like crazy trying to find it.
Old Oct 10, 2008 | 07:37 PM
danskool's Avatar
danskool
Go Bills !
Did you check to see if the harnesses on both covers, Externally ,were pushed in all the way? And the 42 pin connector was secure and the 42pin connector wires aren't rubbing the valve cover?
Old Oct 10, 2008 | 07:41 PM
megawatt00's Avatar
megawatt00
I searched my butt off to find it!!!! I have it saved now though!
Old Oct 10, 2008 | 07:57 PM
7.3mule's Avatar
7.3mule
no dan but i will do that first thing in the morning
Old Oct 10, 2008 | 07:58 PM
7.3mule's Avatar
7.3mule
do both have the 42 pin connect? or just one side and which side would it be?
