Does anyone know of a way to figure out what front spring code I've got without having a door sticker? My trucks had a cab put on it and has a salvage title so i have no sticker. I put in an add a leaf last year and it really didnt do all that much and I'm wondering how much the x codes would help-I've found some for 75 each. Thanks
I see post #4, are you talking about measuring the thickness of the leaves? Seems like the 4 most common ones that I would have are all the same thickness?
Ill check later this afternoon to verify, but I believe on my 2002 ECSB, it had R code springs. And on our 2002 CCSB I think had the next size heavier, V codes. But I can also check out early 99 and see what it has, its also an ECSB.
Well, our early 99 doesnt have its sticker anymore, but I was correct. Mine had R codes (4800 FAWR) and the Crew cab short bed truck has V codes, (5200 FAWR)
