Sponsored by: Real Truck
Leaf spring codes
Old Mar 17, 2008 | 05:32 PM
40searay's Avatar
40searay
Leaf spring codes
I've looked over a LOT of posts and the tech folder but for some reason, I can't find my spring codes. I may just be going blind!
I have a VY spring code on my sticker but the front springs, after 50,000 miles have a negative arch. Should I move up to the X spring code?
Old Mar 17, 2008 | 08:39 PM
99f350sd's Avatar
99f350sd
With the 6.0 I would have the X's no problem. I have em in mine and I have the 5.4..
Don't hesitate..It might go up 2 inches or so.
dick
Old Mar 18, 2008 | 06:59 PM
40searay's Avatar
40searay
The truck sits only slightly nose down right now. About 3/4 inch less than the front. I'm assuming that when I change springs, I may be nose high for a while until the new springs assume the 'position' and loosen up. How does your truck ride with the X springs?
Old Mar 18, 2008 | 07:10 PM
99f350sd's Avatar
99f350sd
Still tail up
bigboylk
Apr 15, 2013 06:20 PM
Sader
May 21, 2011 07:33 AM
bumblebee902
Oct 16, 2010 01:34 PM
broncorif
Mar 23, 2010 06:20 PM
stewcon
Feb 7, 2005 07:27 AM
