Heater Problem
Old Oct 10, 2008 | 02:45 PM
jsutton's Avatar
jsutton
It's not bad just look at the heater core replacement instructions
https://www.ford-trucks.com/article/...es_Trucks.html
I used those to do mine and it was a great help. It says you don't have to pull the big box from under the hood but I did anyway and you may need to so you can get to the blower motor inside there easier. You may be able to do it all with it still in the truck but, it'd be a lot easier sitting on the ground. Just my .02 again.
Old Oct 10, 2008 | 06:29 PM
Alvin in AZ's Avatar
Alvin in AZ
Just my .02 again.
Cool post. :)
Same here! :)
But had to lower the -fender apron- to get the black box out!
For me it wasn't about easier.
It was all about doing the best job I could do. :)
Put it back together improved if I could.
It's easier to slap the sucker back together as if you are working on your
mother-in-laws pickup. I wasn't, so I didn't. ;)
For some "standing on your head" under the dash is easy, others it ain't? :)
I insulated the box, and did all sorts of stuff I can't even remember. :)
Alvin in AZ
Old Oct 10, 2008 | 06:34 PM
Alvin in AZ
Figure out a way to get to it and just pull the wires off of the "accessory relay"?
Buy a new relay, plug the wires into it and deal with it later?
I don't know if "Ford window relay" means anything but those were the magic
words said before receiving the only relay that's lasted. ;)
Alvin in AZ
ianobetz
13
Feb 24, 2015 08:17 PM
Pablo-UA
Aerostar
15
Dec 2, 2007 02:40 PM
dropped74
Jan 12, 2006 11:09 AM
slayer1958
Nov 20, 2005 09:16 PM
Voksboy
May 10, 2004 03:45 AM
