General Automotive Discussion
GM column connector
Old Oct 8, 2008 | 09:07 PM
Ford_Six's Avatar
Ford_Six
GM column connector
I am working on a Jeep Wagoneer, and I can't find a worthwhile wiring diagram for this thing. It has a GM column, and I need to know which wire is which on the turn signal harness connector. There is an article on here that tells the wire colors, but that doesn't match up to the truck.
Does anybody know the pinout of this connector?
Old Oct 9, 2008 | 11:54 AM
Ford_Six's Avatar
Ford_Six
Anybody? Even just which one is the power coming in?
Old Oct 9, 2008 | 01:23 PM
Monsta's Avatar
Monsta
Sit. Stay.
Wouldn't a test light help you?
Old Oct 9, 2008 | 05:17 PM
Ford_Six's Avatar
Ford_Six
Not after you cut the old harness out, and are in the process of installing the new one.
I did find a nicely done diagram, in the first post here:
Check out my wiring diagram - International Full Size Jeep Association
If anyone wants to modify the article here on using GM columns, that would probably be a good thing. A google search of GM column wiring turns up the article here as the top hit.
Gigemags05
Dec 4, 2014 01:56 PM
Corn Fed
Nov 10, 2013 07:26 PM
ferguson777
17
Jul 24, 2012 07:11 AM
sgtnike
Feb 18, 2012 03:10 PM
fe8u
Aug 10, 2009 10:58 PM
