Offroad & 4x4
Tow Hooks
Old Mar 15, 2001 | 11:39 AM
kassonb's Avatar
kassonb
Tow Hooks
I have a 1990 F-150 4.9l 5speed 4x4 and I would like to add tow hooks on both ends in a manner that will not adversly effect the truck if they get used hard. Any suggestions as to what the best type are, the best mounting procedure and where to get them?
Thanx in advance.
Old Mar 15, 2001 | 01:02 PM
kassonb's Avatar
kassonb
Tow Hooks
[font size="1" color="#FF0000"]LAST EDITED ON 15-Mar-01 AT 02:17 PM (EST)[/font][p]Never mind. I found them at JC Whitney and http://www.tooldealz.com/towhook.html :-).
I do still have one question.
Is there a problem with mounting them directly to the frame? I read something that said there were problems with that but did not go into any detail.
Old Mar 15, 2001 | 02:56 PM
traildawg's Avatar
traildawg
Tow Hooks
Actually, the frame is the ONLY place you want to mount them. If you bolt them on, make sure to drill the proper size hole so there's no (incoming highly technical term) wobble, as this could allow the hooks to move when being pulled on and possibly stretch the holes. Best bet is to weld them on, but properly bolting them on works just fine as well.
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
4.9L-Auto
Pro-Comp Stage-2 6" lift
Auburn Pro-Series Diff. w/4.30:1 gears
35x12.50x15 General Grabber MT's
http://www.geocities.com/ProjectTrailDawg
Old Mar 15, 2001 | 08:59 PM
oldblue18's Avatar
oldblue18
Tow Hooks
Do not weld them on!!!!!! A weld will break long before a quality bolt will.
Old Mar 16, 2001 | 02:53 PM
proeliator's Avatar
proeliator
Tow Hooks
Agreed. You want to bolt them on with grade 8 bolts rather than welding. There have been some dramatic failures with tow hooks welded onto the frame. D-rings are always a good option as well.
If your knuckles ain't bleeding you did something wrong.
'72 F-250 "Hi-Boy" 4x4, Dana 60/HD44, FE390 @ 400hp(purt near!), 4-speed, custom suspension w 4" lift, mud on black.
Old Mar 19, 2001 | 09:24 PM
p3i's Avatar
p3i
Tow Hooks
[font size="1" color="#FF0000"]LAST EDITED ON 19-Mar-01 AT 10:25 PM (EST)[/font][p] If you got hooks from JC then your best bet is to bolt them through the provided holes and just use them for looks. If you want something to pull your truck out then get some serious metal (1 inch round stock bent into a hook ) and have a welder weld them to the frame. Whoever says this is a bad idea obviously doesn't know how to weld, or is to cheap to pay a welder. I have pulled and snatched a lot with mine with no problem.
Old Mar 19, 2001 | 11:31 PM
mrlaserboy's Avatar
mrlaserboy
Tow Hooks
I agree with not welding the hooks to the frame. You should not weld on a frame anyways. Go with bolts and torque them correctly and you should be set.
Dustin Siebert
mrlaserboy(No Email Addresses In Posts!)
Registry: http://www.superford.org/cgi-bin/sf.cgi?uid=default&vr2=1&ID=201
Home Page: http://www.superford.org/users/ylobronc/index.html
'88 Bronco XLT 302EFI/AOD/BW1356/44IFS with 8 lugs(open)/10.25 FF(Lockright locker)/4.56/6" Superlift/2" BL/35's-street/38.5's-trails
2 BIG BRONCOS 4X4 CLUB - GREAT LAKES CHAPTER http://www.2bigbroncos.org
Old Mar 20, 2001 | 01:52 PM
proeliator's Avatar
proeliator
Tow Hooks
Sigh. And now its time for a little physics lesson for p3i. The problem with welding tow hooks onto a frame is not the quality of the welds, but that the application of that much heat weakens the surrounding metal. Its all about temper. Just like applying enough heat to a steel blade will ruin its temper and weaken it, so will it your trucks frame. Does this mean that a tow hook welded to your frame will neccesarily break? Not at all. Does it mean that anything welded is weak or will break? No, provided it was welded properly. However, it does mean that a welded tow hook will give before one applied with grade 8 bolts. School is out.
Old Mar 20, 2001 | 09:38 PM
Ultramagdan's Avatar
Ultramagdan
Tow Hooks
I've see the rounded one inch hooks break. The bolts didn't.
98 F250LD 4X4
Old Mar 25, 2001 | 11:05 PM
mj's Avatar
mj
Tow Hooks
Old Mar 29, 2001 | 07:21 PM
AlM's Avatar
AlM
Tow Hooks
although this is for a bronco..look at these pics and ideas:
http://mybigbronco.com/cgi-bin/ikonboard/topic.cgi?forum=1&topic=340
Old Apr 4, 2001 | 09:00 AM
kassonb's Avatar
kassonb
Tow Hooks
Thanx everyone - they will be bolted to the frame. :-)
Bruker
1983 - 2012 Ranger & B-Series
Sep 7, 2009 07:53 AM
nugent_crai
Jan 20, 2009 11:44 AM
06WhiteSport
Feb 22, 2007 10:12 PM
Squishy
Offroad & 4x4
Nov 8, 2005 11:20 PM
captain morgan
Jul 13, 2005 05:58 AM
