Throttle position sensor problems
Old Oct 8, 2008 | 07:52 AM
Ricky Mayo's Avatar
Ricky Mayo
I have a 2005 f-150 street boss with 79000 mile, and it is shooting off going down the road, and the check engine light is flashing. The first time I started it back up and it would idle fine, but the throttle wouldn't do any thing. After setting about 15 min. I started it up and it ran good. I checked the codes and it had a p2104 Throttle acturator control system forced idle. It happened again with my wife. This time when I checked the codes it had the p2104 and a p2112 throttle actuator control system stuck closed code. Does any one have an idea what could be the problem, or a troubleshooting guide I could use to try and diagnose it. Thanks
Old Nov 8, 2009 | 09:20 AM
Leew222's Avatar
Leew222
How did you make out w/ that? I am having this problem now. Thanks Lee
Old Nov 9, 2009 | 01:56 AM
SMok's Avatar
SMok
Usually the throttle body causes this problem about 95% of the time.
Old Nov 9, 2009 | 01:29 PM
Leew222's Avatar
Leew222
Is the TB only available from Ford? Thanks for the info.....
Old Nov 9, 2009 | 02:19 PM
Leew222's Avatar
Leew222
2006 f250 5.4 throttle body
Does anyone sell a decent aftermarket throttle body for a 2006 5.4 f250 that is less $$ than Ford? Thanks Lee
Old Jan 24, 2014 | 08:57 PM
popeye_59's Avatar
popeye_59
Try cleaning it first they usually stick because their dirty with carbon.
Old Jan 25, 2014 | 02:03 PM
Mattjcott's Avatar
Mattjcott
I had the same problem with my f250. Take the throttle body off give it a good cleaning and a new gasket and you're good to go. Maybe took me an hour to complete.
Old May 11, 2020 | 10:19 PM
bigbulls's Avatar
bigbulls
I just went through this EXACT same thing. It was the Throttle position sensor shorting and causing the truck to go into failsafe mode and forced idle or shut off completely. Throwing codes 2104, 2111, 2135. The TPS is on the passenger side of the TB. Two screws secure it to the TB. You don't need to replace the entire TB. Pull the TB, clean it really well, replace the TPS and re calibrate the TB.
Link to my issue. https://www.ford-trucks.com/forums/1...safe-mode.html
Explaining the problems with the generations of TPS's
Old May 11, 2020 | 10:22 PM
bigbulls's Avatar
bigbulls
Follow this procedure for re calibrating the TB/PCM.
Old May 11, 2020 | 10:28 PM
bigbulls's Avatar
bigbulls
J***** C*****.... I just realized how old this thread was. Oh well, maybe it will help someone else with the same issue.
LilToe
Dec 4, 2012 11:53 AM
chop33
Jan 6, 2011 09:57 PM
Dales F-350
Jan 2, 2010 09:34 AM
Mary_Kate_Olsen
1978 - 1996 Big Bronco
Oct 5, 2003 10:29 PM
gdoggy
1983 - 2012 Ranger & B-Series
Jun 19, 2003 09:48 PM
