Serpentine belt
Old Oct 7, 2008 | 11:41 AM
madjak's Avatar
madjak
Serpentine belt
Need to replace my serpentine fan belt. Not sure who makes the best....
Dayco, Gates, etc. Would appreciate any recommendation.
Thanks
Old Oct 7, 2008 | 11:53 AM
mndiesel's Avatar
mndiesel
I have a gates and no problems so far (6 months)
Old Oct 7, 2008 | 12:12 PM
Ponyboychris's Avatar
Ponyboychris
I've used Gates with no issues.
Old Oct 7, 2008 | 12:18 PM
rbaker6336's Avatar
rbaker6336
I use OEM on mine but learned long ago not to uses dayco
Old Oct 7, 2008 | 01:33 PM
madjak's Avatar
madjak
Thanks guys. I will probably go with Gates.
Old Oct 7, 2008 | 02:08 PM
Ponyboychris
Just curious, why not Dayco? Fit issues? Poor quality?
Old Oct 8, 2008 | 11:34 AM
cvdenson's Avatar
cvdenson
I like the Goodyear Gatorbacks. I've had no problems with them on any vehicle I've owned.
Chris
Old Oct 8, 2008 | 12:05 PM
UP_There's Avatar
UP_There
another vote for Goodyear Gatorback
Old Oct 8, 2008 | 12:40 PM
harleydude03's Avatar
harleydude03
napa 115,000 miles
Old Oct 8, 2008 | 02:41 PM
schlepprock250's Avatar
schlepprock250
I replaced mine with a NAPA belt(twice) but theres a problem somewhere....something keeps causing one edge og the belt to get chewed off!
Old Oct 8, 2008 | 07:30 PM
randomhero1172's Avatar
randomhero1172
That would be your tensioner pulley. If they are older and get bent just a touch it will cause your belt to rude up on your AC pulley and wear at it. Happend to mine about 3 times. Tensioner is cheap, one bolt.
On the belt issue - the cheapest one you can get! Inspect regularly and keep a spare with an alternator.
Old Oct 8, 2008 | 08:21 PM
aldridgec's Avatar
aldridgec
I had a problem with the gatorback on my truck and a few other instances of it have occured. The belt will resonate between the alternator and the p/s pump. Some other belts have been know to do it but the gatorback is just especially flexible.
FWIW, I have the belt I used breifly if anyone wants it. I'll never use it. A friend of mine said I should keep it in the truck incase mine were to break, but honestly, I've never had a belt break and if it would break I'm sure there would be another reason for it.
WhozeYoDaddy
Jul 6, 2015 10:31 AM
megawatt00
98
Feb 23, 2010 02:42 PM
ford2go
General Automotive Discussion
Dec 23, 2009 09:24 PM
blakeusa
13
Feb 10, 2009 09:15 PM
SPL Tech
15
Sep 27, 2007 10:42 PM
