tjbeggs and others with the e4od "the cure"
on
I think this module works by increasing line pressure doesn't it? Not trying to highjack this thread but I have the Trans Command made my Banks. It helps , some . But I think the only way to really fix the
E4OD shift problems is to go through the valve body. I have all the new accumulator valves and new line pressure modulator valve for mine. Hope to get time this weekend to fix it. Another problem with E4OD's is the line to lube pressure regulator valve in the pump. I am hoping I do not have this problem... The guys at Sonnax are very helpful if the cure desn't do what you ned on your truck Wildstang.
on
Thanks Neal! It happened about the same time as TW's chip so my power increase was
That is correct. The Cure can be used with any trans mods from a sonnax tri spring kit to a full on BTS transmission
Sick6
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
12-29-2015 11:06 AM
thegorilla
15
05-22-2014 08:38 AM
knuckleheadnut
26
05-17-2012 09:29 PM
auerdoan
16
12-24-2010 12:53 PM
ClydeSDale
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-17-2009 02:25 AM
