Sponsored by: Real Truck
Door Ajar Problem
Old Oct 6, 2008 | 09:46 PM
bstegelmeier's Avatar
bstegelmeier
Door Ajar Problem
Help! I'm stuggling with a door ajar problem. This is a 2007 XLT crew cab 6.0 L PSD that I'm rebuilding. The door ajar warning keeps coming up and the dome lights want to be on all the time. I have taken the door apart and tested all the switches. The front doors have power to the switches and the switches close when the door is closed. The back doors do not have power to the switches; however both switches close when the doors are closed. I wonder if the doors are not getting power. I have checked the fuses and all seem to be working except for 30, 31 and 32 that the owners manual indicate are for the high beams, the starter relay, and the radio. All of these seem to work well.
Could this be a bad relay?
Thanks in advance!
Old Oct 6, 2008 | 10:47 PM
CousinCarl's Avatar
CousinCarl
I had a 2000 mazda b-series truck with the same problem. the dome light stayed on indicating the door was ajar even though it was shut. I researched the problem online and found it was an issue common with ford (mazda is made with ford parts). I found that by adding WD-40 to the door jam latch would cure it. The latch was stuck open and would not latch down when the door shut, leaving the door ajar light and dome light to stay on. And sure enough just simple wd-40 fixed the problem. how easy right?
Old Oct 6, 2008 | 11:00 PM
bstegelmeier
It isn't in the switch.
I started with the WD40 fix. All four switches work. I took apart the doors and checked each one. They all close when the door is closed.
Thanks,
Old Oct 7, 2008 | 09:11 AM
bstegelmeier
Test Relay
Does anyone know how to test the relays?
Thanks!
Old Oct 11, 2008 | 10:28 PM
bstegelmeier
Can you switch relays to test them?
Thanks
Hiflyer746
17
Mar 20, 2009 08:02 PM
Hiflyer746
Feb 25, 2009 11:22 PM
bstegelmeier
Dec 23, 2008 05:45 PM
Scout
Apr 6, 2005 12:11 AM
