E4od ??
Old Oct 5, 2008 | 07:38 AM
RP27G8G's Avatar
RP27G8G
E4od ??
How do I tell the difference between gas and diesel E4ODs or are they the same transmission? I have a 91 diesel and found a good used trans. I know up to 96 will work but the later ones require the newer solenoid pack pigtail.
Thanks!
Old Oct 5, 2008 | 02:19 PM
85e150's Avatar
85e150
Different ratios and bolt pattern. Not sure about ID tags, but the bell pattern would be the most obvious.
Old Oct 6, 2008 | 08:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Same ratios and different bolt patterns. There was only one set of ratios for all E4ODs.
Old Oct 6, 2008 | 11:28 AM
85e150's Avatar
85e150
Sorry, I was thinking ZF in the background here....
