Offroad & 4x4
coil spacers
Old Apr 7, 2001 | 10:24 PM
airwulf's Avatar
airwulf
coil spacers
was reading in a four wheel magazine about a new (fj80) toyota land-cruiser that had acheived i think 3 or 4 inches of lift using coil spacers, i guess just a donut-shaped block at the top of the spring, instead of taller springs. do they have those for fords/are they a reasonable option/would they be cheaper than new taller springs?
Old Apr 9, 2001 | 07:26 AM
72f100's Avatar
72f100
coil spacers
They might be alittle cheaper if you can find them. I have never seen spacers for old Fords. I'd just get the coils. They aren't very expensive and they have the advantage of greater travel that a spacer can't provide. You have to get new shocks either way so I would get the coils. 6" coils from 4wheel aprts are only like $140 or so delivered. If you want a cheap way to gain 2"-3" take a piece of 2-3" square tubing (at least 1/8" thick preferably 3/16 or 1/4") and weld it to the bottom of your frame in the front and move your spring perches down attaching the bottom bolts to the square tubung you welded on. Even after you buy a dropped pitman arm to correct steering you should still have less than $75 in the job.
"Like a Rock"; on the sides of roads everywhere.
Old Apr 11, 2001 | 02:37 PM
magnus's Avatar
magnus
coil spacers
[font size="1" color="#FF0000"]LAST EDITED ON 11-Apr-01 AT 03:37 PM (EST)[/font][p]If you don't want to spend money on new coils (which offcourse are better) and like hanging out in wreckyards look for one off a bigger truck than yours. I used coils from a 2wd f250 to lift my 77 Bronco 4". they bolted right in and cost 10 bucks.
If you didn't build it, its not really yours.
Old Jul 8, 2001 | 08:00 PM
billyb's Avatar
billyb
coil spacers
Old Jul 9, 2001 | 10:50 AM
AZ4x4f150's Avatar
AZ4x4f150
coil spacers
I have a 82 f150 and was turned to Daystar products who makes urethane bushings and invented the spacer for the Dodge now makes a 2" spacer for the Fords the factory gave me a prototype kit for my truck to try it works great. now i am a Daystar dealer. The spacers should be coming out on the market early fall of 2001 send me an email and I will give you more info
Uni Moe
Dec 12, 2016 10:57 AM
Ryc91
Mar 1, 2016 10:23 AM
bigbadbob17
16
Apr 27, 2014 07:36 PM
400inatruck
26
Dec 23, 2013 05:44 AM
roguebronco36
1978 - 1996 Big Bronco
Dec 29, 2001 01:56 AM
