Sponsored by: Real Truck
Mercon SP
Old Oct 4, 2008 | 02:47 PM
NorCalBusa's Avatar
NorCalBusa
Mercon SP
My 2007 Dsl tranny calls for only this product- can't find it anywhere (haven't been to the dealer for it). Is it unobtaniuim?
Old Oct 4, 2008 | 03:07 PM
NORTHLAND06's Avatar
NORTHLAND06
You can get at dealer only. SP is for the torque shift tranny's only in a Super Duty with diesel and V10 motors only. Use only SP fluid only. I have Super Duty and it has same stuff. Torque Shift Tranny's are in the newer SD I think 04 and newer.
Old Oct 4, 2008 | 04:43 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Yep... Mercon SP is dealer or online. It is rare that you will find it sold anywhere else...
Old Oct 4, 2008 | 06:02 PM
NorCalBusa's Avatar
NorCalBusa
Thanks guys!
Old Oct 4, 2008 | 06:45 PM
99f350sd's Avatar
99f350sd
Saw some at wally world I think..
Old Oct 4, 2008 | 07:10 PM
UGA33's Avatar
UGA33
That would be awesome but i highly doubt it
Old Oct 4, 2008 | 07:28 PM
99f350sd's Avatar
99f350sd
I was there getting some mercon and I thought I saw some sp like 3 days ago cause I said to myself oh look there's some of that stuff...
Old Oct 4, 2008 | 07:40 PM
UGA33's Avatar
UGA33
Im gonna go check mine tomorrow! That would be awesome!!!
Old Oct 4, 2008 | 08:58 PM
NorCalBusa's Avatar
NorCalBusa
Walmart is where I've found Motorcraft oil filters for my truck- be cool to find fuel and air too!
Old Oct 5, 2008 | 08:02 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by NORTHLAND06
SP is for the torque shift tranny's only in a Super Duty with diesel and V10 motors only......Torque Shift Tranny's are in the newer SD I think 04 and newer.
TorqShift started in 2003 with the 6.0L diesel. In 2005 the 5.4L and 6.8L also got the TorqShift.
Old Oct 5, 2008 | 02:32 PM
cartmanea's Avatar
cartmanea
It would be great if Walmart could get it, the dealership prices it like its liquid gold.
Old Oct 5, 2008 | 03:14 PM
PowerStrokeHD
Ford/Motorcraft raised the prices to dealers again on 10/01, so it is more like liquid platinum now. Current suggested retail price is like $78 for a case of 12 quarts...
Old Oct 5, 2008 | 03:35 PM
cartmanea's Avatar
cartmanea
Yeah, I paid right at $6/qt two months ago for a case of 12.
Old Oct 5, 2008 | 06:20 PM
mhoefer's Avatar
mhoefer
So, I see in the tech folder, the flush technique is not working, anyone able to get it repaired? I am at 80,000 Km and could probably just drain the pan and refill, but I was thinking I should also change the external filter and try the flush? Problem is the instructions stop at pan drain and dont explain the hose attachments to drain the converter properly from the external lines. Could someone walk through the process after draining pan and refiling, then I connect 1/2 inch OD tube too?, 1/2 inch inside d tube too, and pump dirty oil from return line into measured container while pouring in clean into tranny fill tube? PLus, wow, 20 quarts of Mercon SP is going to require a take out mortgage, maybe I should just get a case and drain pan and change external filter?
Old Oct 5, 2008 | 06:52 PM
NorCalBusa's Avatar
NorCalBusa
All that...is why I simply took mine in. $180 later, and nothing all over my arms to clean up LOL! I also wanted to document the tranny service with a Ford dealer/FoMoCo, not so worried about documenting my own oil/fuel changes.
