carb problem?
Old Oct 11, 2008 | 06:19 AM
  #31
SPINPOSI's Avatar
SPINPOSI
WOW, good call Alvin!
Old Oct 11, 2008 | 12:23 PM
  #32
fmc400's Avatar
fmc400
MSEE
Originally Posted by Pud12343
sure enough it does have 1.08 haha, is that bad?
It could be. 1.08 is a 287 CFM carburetor. Assuming you get up to 3000 RPM in most of your driving, you should be looking for around 340 CFM. But that should not make it sputter. You've got your mind made up that the problem is the carburetor, but you need to consider the other things people are telling you. Did you check your timing yet? I skimmed through the thread since the last time I suggested it and I couldn't see anything saying you did. Your problem sounds like timing to me. Check the base timing, and check your vacuum advance for a vacuum leak. I can't seem to find a response of yours saying you did. If you don't check things step by step and follow our instructions, we are of no use to you. A lot of people make life harder on themselves because they think "I don't have a timing light, so timing probably isn't the problem anyway." That's the worse way to diagnose engine problems.
(Sorry if you already did, I just can't seem to find it in the thread).
Old Oct 11, 2008 | 05:31 PM
  #33
Pud12343's Avatar
Pud12343
sorry, after you said to check the timing, i think i posted and said that i didnt know how to do that, and no one really said anything about how to so i just tried all the other stuff.....
Old Oct 11, 2008 | 05:33 PM
  #34
Pud12343's Avatar
Pud12343
sorry, it was chuck101st that said had i checked the timing lately
Old Oct 11, 2008 | 05:54 PM
  #35
Pud12343's Avatar
Pud12343
and fcm400, im really greratful for all your help, not trying to be rude at all, and i just read what i wrote and realized it could be taken that way. but just wanted to say i didnt mean it to be offensive
Old Oct 11, 2008 | 06:16 PM
  #36
fmc400's Avatar
fmc400
MSEE
No problem at all, just trying to cover all the bases. Here is a writeup I made a while back that goes over how to set your timing (ignore the first couple paragraphs about Carter carbs).
https://www.ford-trucks.com/forums/7...ml#post6480725
Old Oct 11, 2008 | 07:09 PM
  #37
Pud12343's Avatar
Pud12343
alrght, thanks!
