carb problem?
Old Oct 4, 2008 | 09:37 AM
Pud12343's Avatar
Pud12343
carb problem?
ok, when i got my 76 f100, i knew NOTHING about how engines work or any of the parts on them, but recently ive been learning alot, but i hae no idea about stuff like this. When i pull out in my truck, it feels great, but if i all the sudden slam onthe gas, it just kinda boggs down and feels like it has no power. the engine is a 390 4bbl, but the guy i bought it from put an autolite 2bbl carb on it and a 2" carb spacer. does it just need a bigger carb or is there some other problem?
thanks!
Old Oct 4, 2008 | 10:13 AM
chuck101st's Avatar
chuck101st
Could be the accelerator pump in the carb.. Or the fuel filter. Have you checked the timming lately?
Old Oct 4, 2008 | 10:18 AM
Pud12343's Avatar
Pud12343
haha, i have no idea how to
Old Oct 4, 2008 | 11:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Pud12343
ok, when i got my 76 f100, i knew NOTHING about how engines work or any of the parts on them, but recently ive been learning alot, but i hae no idea about stuff like this. When i pull out in my truck, it feels great, but if i all the sudden slam onthe gas, it just kinda boggs down and feels like it has no power. the engine is a 390 4bbl, but the guy i bought it from put an autolite 2bbl carb on it and a 2" carb spacer. does it just need a bigger carb or is there some other problem? thanks!
The engine bogs down, hesitates, craps out.
This is the typical problem shared with every Ford 2V carb from 1963 thru 1979.
The accelerator pump diaphragm & check valve are in need of replacement.
Since I don't know what 2V carb you have, I can't post the part number for the accelerator pump.
The check valve is the same 1963/79 (C4AZ9576A Motorcraft CM825), but Ford changed the accelerator pump diaphragm in 1975.
The acc pump diaphragm is located on the front of the carb behind a cover with a lever. 4 bolts hold this cover on.
Be very careful when you remove the cover, there's a COIL SPRING behind it. The check valve is behind the pump diaphragm.
1974/76 390's came with a 2V carb as standard equipment, A 4V carb was an option.
When a 4V was factory installed on a 390, the engine code in the VIN is different.
The 4th digit of the VIN is the engine code: H = 390 2V / M = 390 4V / Y = 360 2V.
Is it really a 390? On sale day, 360 engines magically turn into 390 engines.
Old Oct 4, 2008 | 11:27 AM
Pud12343's Avatar
Pud12343
um, as far as i know its a 390, the code for the engine is H, but it has a 4bbl intake, maybe aftermarket, but doesnt have any brand name that i can see
Old Oct 4, 2008 | 11:28 AM
NumberDummy
H = 390 2V.
How can it have a 2 barrel carb on it, if the intake manifold is for a 4 barrel?
Old Oct 4, 2008 | 11:42 AM
Pud12343's Avatar
Pud12343
it has a 2 to 4 bbl carb adapter
Old Oct 4, 2008 | 12:47 PM
fmc400's Avatar
fmc400
MSEE
Sounds like the accelerator pump to me too, but I think having a 2 barrel carb on a 4 barrel intake is worthless. I think the main reason people do that is when they are selling a truck but want to keep the carb, so the throw something on there to keep it running so that it can be driven away.
Old Oct 4, 2008 | 10:49 PM
Pud12343's Avatar
Pud12343
so what exactly should i do, like it runs good, but when i slam on te gas it doesnt get above 3000 rpms
Old Oct 6, 2008 | 05:49 PM
Pud12343's Avatar
Pud12343
no body else haha? i was gonna get a 4 barrel carb, but dont know what cfm, and ideas on that?
Old Oct 6, 2008 | 06:02 PM
saleen065's Avatar
saleen065
The factory 4bbl is a Holley 600cfm. Go and get a replacement carb from any autoparts store. That's what I did and mine runs great.
Old Oct 6, 2008 | 06:40 PM
fmc400's Avatar
fmc400
MSEE
Pull the air cleaner off the motor with the truck shut off, and look down the throat of the carb. Pull back on the throttle, and you should see two streams of gas shoot across the venturis. If you don't, the accelerator pump is not functioning. If you do, we'll move on to some other checks.
Old Oct 6, 2008 | 06:53 PM
gearhed1971's Avatar
gearhed1971
Had the same problem w/ mine ,but got backfire through the carb.Advanced timing to 11 degrees and runs like a champ
Old Oct 6, 2008 | 09:59 PM
Pud12343's Avatar
Pud12343
yea, it squirts gas from both
Old Oct 6, 2008 | 10:48 PM
fmc400's Avatar
fmc400
MSEE
Check your base timing, and it wouldn't hurt to make sure your distributor vacuum advance holds vacuum. You can check this by applying vacuum to it and watching for the base plate in the distributor to move with the cap off. I myself wouldn't be wasting my time with a 2 barrel carb on a 4 barrel intake; I'd go ahead and put a 4 barrel on it.
