carb problem?
Old Oct 6, 2008 | 10:54 PM
SPINPOSI's Avatar
SPINPOSI
Does it idle somewhat fine, but sputter when trying to accelerate?
-Jason
Old Oct 6, 2008 | 10:59 PM
SPINPOSI's Avatar
SPINPOSI
If it sputters I would look at your plugs or rotor & cap.
If it just looses power might be timing or Vacuum advance.
Maybe replace the fuel filters for good measure...
Good luck!
-J
Old Oct 6, 2008 | 11:24 PM
Pud12343's Avatar
Pud12343
it does exactly like that, it idles and if i pull out really easy(no fun) then its fine, but if i pull out hard it sputters and if im already moving and try to pass someone the power just isnt there anymore
Old Oct 6, 2008 | 11:26 PM
Pud12343's Avatar
Pud12343
and i just put new plugs in about a month ago, and new msd plug wires, rotor and cap a few weeks ago, the plug in the first cylinder one the drivers side is getting REALLY bad black powdery buildup on it tho
Old Oct 7, 2008 | 12:01 AM
SPINPOSI's Avatar
SPINPOSI
I'm going to stick my neck out and call it fuel starvation....
If I was having that problem:
I would replace all the rubber fuel lines and fuel filters.
2100 carb most likely so I'd Pull the top off the carb (few flat head screws and choke linkage) and clean every hole with choke & carb spray. Don't drop anything down the carb.
I'd pull the float/needle.
Then pull the jets (2 round brass things under float) and shoot in there too.
You could pull the venturi assembly, but I would remove the carb from the engine. too risky over the intake.
Then reassemble being sure the gasket didn't get torn during disassembly.
Just my .02 cents worth to fix with minimal cost.
-Jason
These pics credited to www.valvoline com
Old Oct 7, 2008 | 02:41 AM
Alvin in AZ's Avatar
Alvin in AZ
On the left side of the carburetor there's a number like 1.08 or 1.23 or something.
It's the venturi size in inches and equates to the CFM.
Thinking it might have a 1.08 off a 302 on it. LOL :)
http://www.valvoline.com/carcare/ima...0301cr_s13.jpg
Cool picture. :)
He's got his finger on the emulsion tube and how they are drilled has a big
influence on performance.
What he's holding is called the "booster assembly" and the hollow screw that
holds it down has a steel or sometimes aluminum rod sitting on a ball bearing.
Try to remember those two little parts as you take it apart. ;)
Alvin in AZ
Old Oct 7, 2008 | 11:40 PM
Pud12343's Avatar
Pud12343
you guys have been so much help, i dont even have it fixed an really want to thank you haha. i just got on here for the first time today, ill post up that number and stuff tommorow, but seriously, thank you guys so much for all your help, and i know im gonna need alot more lol
Old Oct 8, 2008 | 06:09 AM
SPINPOSI's Avatar
SPINPOSI
No prob, Good luck!
Old Oct 8, 2008 | 10:28 PM
Pud12343's Avatar
Pud12343
just curious, if the firing order was WAY off would that cause problems like this? i looked up the correct order for a 390 fe and it was completly different. the guy i bought the truck from mustve done it, when i put the new car and rotor on i took them off one at a time and made sure they were on the exact same place, maybe i screwed up tho. i havent had a chance to start it since i changed them, truck has glasspacks lets just say this wouldnt be the first time the neighbors called the cops when i started it late
Old Oct 8, 2008 | 10:41 PM
saleen065's Avatar
saleen065
you have have the firing order wrong, it will backfire and pop like crazy and run like crap.
Old Oct 8, 2008 | 11:18 PM
Pud12343's Avatar
Pud12343
ok, well, its gonna get tested in the morning
Old Oct 9, 2008 | 10:26 AM
SPINPOSI's Avatar
SPINPOSI
Any results?
Old Oct 9, 2008 | 01:00 PM
  #28
Pud12343's Avatar
Pud12343
haha only bad ones, that definatly wasnt it
Old Oct 10, 2008 | 12:23 PM
  #29
Alvin in AZ
Old Oct 11, 2008 | 12:47 AM
  #30
Pud12343's Avatar
Pud12343
sure enough it does have 1.08 haha, is that bad?
