FE oiling improvements
Now the longblock is done and down in my garage. I have been doing the finish work and have a question or two about oiling-
1) The weakest part of an FE is the oiling, so I have followed you guys advice on improving the oiling. The motor now sports a higher volume Sealed Power-brand pump, chamfered oil holes (matching bearings), and a windage tray.
2) I heard that an oil filter adapter from a 428 has larger orifices for increased flow. Any truth in that?
3) The motor was/is a mongrel- the ID tag spec'd a '67 built 410, but the block was a stock bore D3TE, the reciprocating assembly was '67, the heads are '61 hipo/large ports, and the filter adapter reads C5TE-6881-B. 'C5TE' denotes a '65 truck engine, correct? Any help, thoughts, or ideas appreciated-I am building the truck w/o a 'no expense spared' attitude, but I am doing it as properly as possible. Do it right, do it once, and enjoy the fruits of your labor
I hadn't heard the 428 filter thingie before, be careful or you will have everyone scrambling to get one. lol
C & D are indicators of C 60s and D 70s made parts and the T was for truck. The 410 was only used for two years and only in Mercury cars so your 73 or later D3TE block was originally a 360/390 truck block. That questions the 67 ID tag that you made reference to.
Just running the 428 crank in the 360/390 block makes a torque monster, so you should be able to pull rail cars with it. If you can get an overdrive tranny behind it you should be able to run 2.75 gears and get some really decent mpgs. IMHO
John
orich
7A 330 A
When I first discovered this, I posted it on the forum and thats how I knew I had something strange. The deeper I went, the more odd it got...I even ran into the donor truck's 2nd owner while yarding it out! He bought it from an old guy who was a Ford nut, then sold it in 1990. The truck had lots of cool stuff in it, but had been in a flood (in 2007) and everything was ruined or picked through by idiots who smashed or broke their way through the truck
You open up the oil passages at the filter area, and plug the ones at the top of the engine with a carb jet. Personally I wouldn't be concerned about a 428 car filter, I don't believe passage at the filter is an issue.
John
-Lance
Hey i've found them on all kinds of vehicles with 390's and even a truck. So keep your eyes open when in the j-yards, but if it's got a casted raised line ridge on top it the small ported one This save you the trouble of getting dirty removing it..there on ebay
all the time..I have extra one...
orich
John
-Lance
I'm sorry but I don't buy it. This I am certain off, there are enough older vehicles out there with money to made off of, the oil companies would be selling oil with the needed additives if they really were needed.
I may have been born at night but it wasn't last night.
John
ZDDP
This page has been created to provide information about a serious deficiency in modern oils. The first word of this came in the form of a posting on the UKMGBB by someone named Scott from Oregon. He posted the following article, written by Keith Ansell:
OIL IS KILLING OUR CARS!!!!!
By: Keith Ansell, Foreign Parts Positively, Inc.
About a year ago I read about the reduction of zinc dithiophosphate (ZDDP) in the oils supplied with API approval that could affect sliding and high pressure (EP) friction in our cars. The reduction of these chemicals in supplied oil was based on the fact that zinc, manganese and/or phosphates reduce the effectiveness and eventually damage catalytic converters and introduce minute amounts of pollutants into our atmosphere.
A month or so ago I had a member of the Columbia Gorge MG Club bring a totally failed camshaft and lifters back to me that had only 900 miles on them!! I immediately contacted the camshaft re-grinder and asked how this could happen. They were well aware of this problem as they were starting to have many failures of this type. In the past, the lack of a molybdenum disulfide camshaft assembly lubricant, at assembly, was about the only thing that could create this type of problem. My customer has assembled many engines and had lubricated the camshaft properly and followed correct break in procedures.
This got me on the phone to Delta Camshaft, one of our major suppliers. Then the bad news came out: It’s today’s “modern” API (American Petroleum Industry) approved oils that are killing our engines.
Next call: To another major camshaft supplier, both stock and performance (Crane). They now have an additive for whatever oil you are using during break-in so that the camshaft and lifters won’t fail in an unreasonably short period of time. They also suggest using a diesel rated oil on flat tappet engines.
Next call: To a racing oil manufacturer that we use for the race cars (Redline). Their response: “We are well aware of the problem and we still use the correct amounts of those additives in our products”. They continued to tell me they are not producing API approved oils so they don’t have to test and comply. Their oils were NOT the “new, improved and approved” ones that destroy flat tappet engines! “We just build the best lubricants possible”. Sounds stupid, doesn’t it, New-Approved but inferior products, but it seems to be true for our cars.
To top this off: Our representative from a major supplier of performance and street engine parts (EPWI) stopped by to “warn us” of the problem of the NEW oils on flat tappet engines. This was a call that the representative was making only because of this problem to warn their engine builders! “The reduction of the zinc, manganese and phosphates are causing very early destruction of cams and followers”. They are recommending that, for now at least, there must be a proper oil additive put in the first oil used on new engines, beyond the liberal use of molydisulfide assembly lube. They have been told that the first oil is the time the additives are needed but remain skeptical that the first change is all that is necessary. Their statement: Use diesel rated oils such as Delo or Rotella that are usually available at auto stores and gas stations.
This problem is BIG! American Engine Rebuilder's Association (AERA) Bulletin #TB2333 directly addresses this problem. I had a short discussion with their engineer and he agreed with all that I had been finding.
Next phone call was to a retired engineer from Clevite, a major bearing and component manufacturer. First surprise was that he restored older British Motor bikes. The second surprise was that he was “VERY” aware of this problem because many of the old bikes had rectangular tappets that couldn’t rotate and are having a very large problem with the new oils. He has written an article for the British Bike community that verify all the “bad news” we have been finding.
Comp Cams put out “#225 Tech Bulletin: Flat Tappet Camshafts”. They have both an assembly lube and an oil additive. The telling sentence in the bulletin was “While this additive was originally developed specifically for break-in protection, subsequent testing has proven the durability benefits of its long term use. This special blend of additives promotes proper break-in and protects against premature cam and lifter failure by replacing some of the beneficial ingredients that the oil companies have been required to remove from the off the–shelf oil”.
Next question: Now what do we do?
From the camshaft re-grinders (DeltaCam) “Use oils rated for diesel use”, Delo (Standard Oil product) was named. About the same price as other quality petroleum based oils. They are not API formulated and have the zinc dithiophosphate we need in weights we are familiar with.
From the camshaft manufacturer (Crane): “use our additive” for at least the first 500 miles.
From General Motors (Chevrolet): add EOS, their oil fortifier, to your oil, it’s only about $12.00 for each oil change for an 8 ounce can (This problem seems to be something GM has known about for some time!).
From Redline Oil: Use our street formulated synthetics. They have what we need!
From our major oil distributor: Distributing Castro, Redline, Valvoline and Industrial oils: “After over a week of contacts we have verified that the major oil companies are aware of the problem”. “The representatives of the oil companies today are only aware of marketing programs and have no knowledge of formulation”. The only major oil companies they were aware of for doing anything to address this are Valvoline that is offering an “Off Road 20W-50” and Redline.
From Castrol: We are beginning to see a pattern emerging on older cars. It may be advantageous to use a non-approved lubricant, such as oils that are Diesel rated, 4 Cycle Motorcycle oils and other specified diesel oils.
Last question: So what are we at Foreign Parts Positively going to do? After much research we are switching to Redline Street rated oils and stocking the Castrol products that are diesel rated. Castrol, owned by British Petroleum, is now just a brand name. This is a difficult decision as we have been a dealer and great believer in all Castrol Products for over 40 years. We have been using Castrol Syntech oil in new engines for about 3 years so the cost difference in changing to Redline is minimal. The actual cost in operation is also less as the additive package in Redline makes a 1-year or up to 18,000 mile change recommended! Yes, it is a long change interval but with lowered sulfur levels and the elimination of lead and many other chemicals in the fuels there are less contaminants in our oil from the fuel, which is the major contributor to oil degradation. We will continue to offer the Castrol products but will now only stock the suggested diesel oils that they produce.
Too many things are starting to show up on this subject and it has cost us money and time. Be aware that “New and Improved”, or even products we have been using for many years, are destroying our cars as it isn’t the same stuff we were getting even a year ago.
For the cars that use “engine oil” in their gearboxes this may even pose a problem as these additives that have been removed could be very critical in gear wear. We will be using oil specifically formulated for Manual Gearboxes with Brass Synchronizers. The only oils we are aware of that fit the criteria are from General Motors and Redline.
If you have any additional input let us know. We need to let every flat tappet engine owner, i.e.: every British Car owner know that things are changing and we MUST meet the challenge.
Keith Ansell, President
360-882-3596
More:
At this time, late October 2006, it appears that our old staple, Castrol, has reduced the ZDDP in GTX to about half what it used to be. The safest bet right now seems to be either the use of Redline (synthetic) or Valvoline VR1. Today I purchased 7 quarts of Valvoline VR1 20W-50 at AutoZone for $2.79/quart.
More from Keith Ansell:
Oil is Killing our cars Part II
Last month’s report on this subject is turning out to be just the tip of the iceberg! Many publications have had this subject of zinc-dialkyl-dithiophosphate (ZDDP) covered in varying depths over the last few months. Some publications have even had conflicting stories when you compare one month’s article with their next month’s article! They are all ending up supporting our report.
I have had the good fortune to have the ear of quite a few leaders in the industry including some wonderful input from Castrol. We have been very reluctant to “dump” Castrol, as it has been such a great supporter of our cars and industry over the years. Castrol hasn’t really abandoned our cars, just shifted to a more mass marketing mode. Many Castrol products are not appropriate for our cars today, some still are.
Now for the latest report:
#1 Castrol GTX 20W-50 is still good for our cars after break-in! 10W-40, 10W-30 and other grades are NOT good. Absolute NOT GOOD for any oil (Any Brand) that is marked “Energy Conserving” in the API “Donut” on the bottle, these oils are so low with ZDDP or other additives that they will destroy our cams. Virtually all “Diesel” rated oils are acceptable.
#2 Castrol HD 30 is a very good oil for break-in of new motors. This oil has one of the largest concentrations of ZDDP and Moly to conserve our cams and tappets.
#3 Only an unusual Castrol Syntec 20W-50 approaches the levels of protection we need when we look to the better synthetic lubricants. We are attempting to get this oil but will be using Redline 10W-40 or 10W-30 as these are lighter weights for better performance, flow volume, less drag and has the additive package we need.
#4 The trend today is to lighter weight oils to decrease drag, which increases mileage. Most of these seem to be the “Energy Conservation” oils that we cannot use.
#5 Redline oil and others are suggesting a 3,000-mile break-in for new engines! Proper seating of rings, with today’s lubricants is taking that long to properly seal. Shifting to synthetics before that time will just burn a lot of oil and not run as well as hoped.
#6 The “Energy Conservation“ trend was first lead by automakers to increase mileage numbers and secondly because the ZDDP and other chemicals degrade the catalytic converter after extended miles, increasing pollution. We don’t have catalytic converters and the mileage gains are not that significant for most of us.
For you science buffs: ZDDP is a single polar molecule that is attracted to Iron based metals. The one polar end tends to “Stand” the molecule up on the metal surface that it is bonded to by heat and friction. This forms a sacrificial layer to protect the base metal of the cam and tappet from contacting each other. Only at very high pressures on a flat tappet cam is this necessary because the oil is squeezed/wiped from the surface. This high pressure is also present on the gudgeon pin (wrist pin) in diesel engines, therefore the need for ZDDP in diesel engines.
Second part of the equation is Molybdenum disulfide (Moly). The moly bonds to the zinc adding an additional, very slippery, sacrificial layer to the metal. I found out that too much of the moly will create problems; lack of this material reduces the effectiveness of the ZDDP. The percentage, by weight is from .01 to .02%, not much, but necessary.
Latest conclusions: Running our older, broken in engines on Castrol 20W-50 GTX is ok.
Break in a new engine for 3,000 miles on HD 30 Castrol.
New engines (after break-in) and fairly low mileage engines will do best with the Redline 10W-40 or 10W-30 synthetic.
We’ll keep you apprised of any new findings! Happy motoring for now!
Paul Hinchcliffe, CCBCC's esteemed head honcho, brought this issue to the attention of William Petitjohn of Lubrication Specialties Corporation. Look for them at Green Velvet Steam Engine and Machinery Lubricants. Among other things, they custom blend a proper lubricant for TC steering boxes. Here's a copy of his response to Paul:
Thank you for your email with the "new, improved, inferior oil thread". This is an old story as many older machines are being left in the dust by the major oil manufacturers. Automotive engine oils drive this entire industry and I think the references to smaller, specialty blenders who still manufacture engine oils with the ZDDP in them is the only real solution as the major manufacturers will always comply with the ever changing high volume requirements of the automobile manufacturers.
We, like the Redline oils have filled the widening gap within the heritage and hobby machine groups our oils address.
ZDDP and other extreme pressure additives are surface modifiers. They modify bearing and journal surface characteristics to allow lubricants to develop more "oiliness" (an old term) or lubricity and reduce the tendency to scuff and gall under heavily loaded boundary lubrication situations. Camshafts and lifters in high speed engines definitely fit this category due to the high velocities and accelerations required to open and close valves many times per second.
We do not manufacture modern automotive engine oils because we do not stock the many additives that make up something like 20% of the total oil by volume. Even though Zinc may not be in many engine oils now other addtives such as detergent dispersants, anti-oxidation additives, viscosity builders, etc are still required. Therefore, the Redline oils may be best because it sounds like they blend their own oils and put in additives that satisfy older engine requirements. It is best to deal with a smaller blender who can tell you unequivocally what is in his oils. I would be leary of the diesel rated oils because these are manufactured by major oil blenders who have a bad habit of changing formulations ***** nilly without prior notice. Diesel engine oil specifications are in a state of turmoil just like gasoline engine oils and zinc additives could easily disappear from these oils too. In fact railroad diesel engine oils have always been zinc free due to conflicts with bearing materials.
The thread is very interesting and confirms my basic business proposition -- It is possible to make a growth business opportunity out of a declining market! We are very happy our PB&J460 formula 3 Green Velvet Pin, Bearing & Journal Oil is working well in your steering gear box. Please refer us to other MG owners as the opportunity arises. Good luck and keep in touch.
Sincerely,
Bill Petitjean
About Bill Petitjean::
Lubrication Specialties Corporation is a blender of specialty lubricants aimed primarily at heritage and hobby machinery requiring straight mineral oil lubricants. Their specialty products include traditional steam cylinder oils, bearing oils for open bearings with boundary mode lubrication, low carbon air compressor oils, compounded marine bearing oils and biodegradable oils for 100% loss lubrication service.
LSC is owned by William L. Petitjean, P.E. and Scott Lindsay and is now located in Stearns, Kentucky. Lindsay and Petitjean together have over 70 years of experience with reciprocating steam engines and bring a wealth of application experience to the specialty lubricating oil business. LSC has recently introduced several old/new oils to their product line in response to the increasing needs of heritage/hobby machine operators. As major oil manufacturers abandon old, non-performing product lines LSC stands ready to fill the gap with traditional products that are necessary to keep older machinery running smoothly and efficiently."
There are also articles supporting this theory written by Crane, Isky and Comp cams. Do a little research.
The reason ZDDP was removed or depleted in modern oils is because it stomps a hole through the catalytic converter, which our trucks obviously don't have. It is also because there aren't any more flat tappet camshaft engines being built anymore, everything now is roller lifter; no more need for ZDDP in a roller motor.
