FE oiling improvements
Old Oct 12, 2008 | 07:57 PM
jowilker's Avatar
jowilker
Bobby, One of my cars has 140,000 miles on it running Havoline and now Advance Auto house brand 5W30, used to run Fram oil filters now use Motorcraft.
Someone please tell me when I should start looking out for failure.
John
Old Oct 12, 2008 | 08:54 PM
BobbyFord's Avatar
BobbyFord
John
When you have more than stock seat pressure on the valves and a brand new camshaft. My last cam was .580 lift. The next one will have mid .600 figures.
Do a search on 460ford.com about camshaft failure.
Your 140,000 mile camshaft was broken in back when oil had ZDDP.
If you won't believe me maybe you'll believe Crane Cams...
http://www.cranecams.com/pdf/548e.pdf
...or it's possible they don't know what they're talking about either...
Old Oct 12, 2008 | 09:59 PM
jowilker's Avatar
jowilker
Sorry bub, is this a racing thing or what? When was the zink removed from the oil? Brand new engines are being cranked for the first time every day.
John
Old Oct 12, 2008 | 10:43 PM
lance65's Avatar
lance65
No john it's NOT a racing thing. You can live in the dream land that you're in now,just dont rub off your ignorance on those that want REAL information. You should NOT pst info on subjects you really dont understand.
-Lance
Old Oct 13, 2008 | 06:39 AM
jowilker's Avatar
jowilker
What year was the zink declared no longer safe & available??
John
Old Oct 13, 2008 | 09:00 AM
Dave Severson's Avatar
Dave Severson
the zinc was removed from oil within the last two years so if your's was built with oil made prior to that date, or if you survived the first 5,000 miles without wiping out the cam lobes, you're ok.
It's not just myth, it's fact. Talk with any of the cam companies and they'll tell you the same thing.... Probably more susceptible to failure on the high lift racing type cams, but nevertheless a consideration on the stock rebuilds also.
For those who care, Royal Purple just came out with a break in oil for the initial run in on new engines. The lack of zinc is not as big an issue with new hydraulic roller cams as it is with the solid lifter and hydraulic lifter engines.
I've got it covered three ways, bought a case of the GM EOS additive (loaded with zinc) and just got a case of the Royal Purple break in oil (loaded with zinc) and plan to use both on engine builds. The third way is that most everything I build is either a hydraulic roller or solid roller cam.
The lack of zinc is an issue, been many articles written by knowledgeable engine builders and cam manufacturers espousing it. Lots of folks who choose to not believe it were rewarded with lobes wiped out on their new cams....not all of them, but a considerable amount. Believe it or don't believe the experts and take your chances. With the cost of rebuilding an engine even to OEM specs, think I'll use the additives and the break-in oil...... I personally know of 2 former non-believers who lost cams on fresh engines this summer, that along with all the articles is proof enough for me....
Old Oct 13, 2008 | 02:01 PM
BobbyFord's Avatar
BobbyFord
John
As I said NEW engines are roller, not flat tappet.
Old Oct 13, 2008 | 06:14 PM
jowilker's Avatar
jowilker
Are you talking for break in or what?
John
Old Oct 13, 2008 | 06:39 PM
Rockstone's Avatar
Rockstone
John
That's the way I understood it based on the Crane Cams link in his #17 post. It says the 1st 20 min of break in are the most critical.
Old Oct 13, 2008 | 06:46 PM
BobbyFord's Avatar
BobbyFord
I also run Valvoline Racing oil (which is high in ZDDP) in my stuff to make sure my cam and lifters last longer. First break-in is critical. A lot of the engine builders on 460ford.com have posted a lot of info on what they've experienced with break-ins and overall cam, lifter and valvetrain longevity. A lot of them run diesel rated oils because of the high zinc content.
Old Oct 13, 2008 | 09:16 PM
Dave Severson
Anyway, best to keep an eye on the ingredients label.... Many of them have no more zinc and don't really bother to mention it....
Even the diesel oils have had the zinc content lowered. Rotella used to be great for break in oil, not sure what they've done to it now... Think I'll be using the Royal Purple break in oil and the GM EOS.
The first 20 minutes is critical on a new cam. With what a good one costs these days, I just would rather not take any chances on wiping out a lobe or three!!!!!
Old Oct 14, 2008 | 05:45 AM
jowilker's Avatar
jowilker
Ah break in, I see now.
If these oils available today are really killing our motors folks would be clammering all over the place, but I don't recall any recent rumbling on the subject.
There is always someone that can't drink tap water that meets all kinds of regulations in favor of expensive bottled water. Spend your money be happy with your fancy label oil, you just might add 6 months to the life of the engine for another few hundred bucks.
John
Old Oct 14, 2008 | 08:13 AM
  #28
lance65's Avatar
lance65
jo,Obviously you refuse to do ANY type of research. But thats OK. You NEED to stop trying to preach your ignorance to those that want FACTS!
-Lance
Old Oct 14, 2008 | 11:21 AM
  #29
jowilker's Avatar
jowilker
Could be Lance, or could be that you elitist thinking empty suit Obama types need to be kept in check.
John
Old Oct 14, 2008 | 03:46 PM
  #30
lance65's Avatar
lance65
jo,I have decide you're not worth the arguement. So as in another post you've managed to destroy with arguing FACTS, I am bowing out. Believe what you will, ignorance ALWAYS has a way of catching up with you.
-Lance
