Offroad & 4x4
more front axle ques.
Old Jul 9, 2001 | 12:23 AM
Gai's Avatar
Gai
can i use newer axle (dana 60 or 50 from the 80's) on the 73 4x4 f-250 frame?
did Ford make a twin i beam suspention on newer 250 / 350 4x4?
i like the soft front suspention on my 76 4x4 f-150 but need a stronger truck
to tow and pull loads.
Old Jul 23, 2001 | 01:00 AM
Jayson103's Avatar
Jayson103
they made independent in f150 and f250 but i am not sure if it would work for what you are doing but i sugest the dana 50 from a f250
Old Jul 23, 2001 | 08:11 PM
alpo23's Avatar
alpo23
Gai, the only dana 60 that will bolt in without any modification is the '78/'79. The 1980 and newer trucks have a wider spring perches. I believe it increased by 3 or 4 inches. The big problem with trying to modify the perches is that the driver side perch is part of the Differential housing and it was moved outboard to follow the wider springs. kind of hard to move it back inboard. FYI, the dana 60 solid front axle returned to the F-350 in '86, from '80 -'85 all had TTB.Good luck.
Eric
Proud owner of a '73 F-250 4x4 High Boy, 460 V8, NP435, NP205, Dana 60 rear w/Detroit Locker
And a '68 Bronco 289 v8 , NP435 , Dana 20
Old Jul 23, 2001 | 08:14 PM
alpo23's Avatar
alpo23
Gai, I just realised the previouse post is misleading. It is the distance between the centers of the two springs that increased, not the actual width of the spring.
eric
Old Jul 25, 2001 | 01:57 PM
Eddie's Avatar
Eddie
You might want to measure where the pumpkin is on the axle in relation to the clearance hump on the engine crossmember.
I know that '78-'79 Bronco/F-150 D-44 pumpkins are 4-5 inches off center for the engine crossmember on '80-'96 F-150, and swapping one in necessitates a HUGE lift for clearance.
Eddie
Old Jul 27, 2001 | 10:05 PM
Ultramagdan's Avatar
Ultramagdan
Melendez7.3
Aug 17, 2015 05:24 PM
DANA60
Sep 9, 2004 07:57 PM
552ford
Dec 4, 2003 10:09 PM
haakeye50
May 23, 2001 03:26 PM
mudslinger
Mar 13, 2001 08:44 AM
